Ramon PG Posted October 16, 2022 Share Posted October 16, 2022 (edited) How can I fix the wacky sequence? Sorting Ascending both the A and B columns shows this. Thanks. Edited October 16, 2022 by Ramon PG Quote Link to comment
Samuel Derenboim Posted October 16, 2022 Share Posted October 16, 2022 VW does sequential sorting, so depending on what you sorted first, it will use that as the primary sorting element. Unsort everything first, and then sort column a first, then column b. I think that should be able to work. 1 Quote Link to comment
Ramon PG Posted October 16, 2022 Author Share Posted October 16, 2022 It doesn't work. I decided to eliminate the suffix and start numbering from 101... on the first floor, 201... on the second floor and so forth. Quote Link to comment
Pat Stanford Posted October 16, 2022 Share Posted October 16, 2022 @Samuel Derenboim I think you got it backwards. You need to Sort on Column B first to put everything into numerical order, then sort by Column A to split them into groups. 2 Quote Link to comment
Ramon PG Posted October 16, 2022 Author Share Posted October 16, 2022 (edited) 3 hours ago, Pat Stanford said: @Samuel Derenboim I think you got it backwards. You need to Sort on Column B first to put everything into numerical order, then sort by Column A to split them into groups. It didn't work... Column B should be Sort: None. Then it works. Now it does work. 🥵 Edited October 16, 2022 by Ramon PG 1 Quote Link to comment
Ramon PG Posted October 16, 2022 Author Share Posted October 16, 2022 (edited) I am also getting wacky results when using tags on doors and applying them to selected objets. I eventually had to do them one at a time. Edited October 16, 2022 by Ramon PG Quote Link to comment
FBernardo Posted October 20, 2022 Share Posted October 20, 2022 On 10/16/2022 at 7:43 AM, Ramon PG said: I am also getting wacky results when using tags on doors and applying them to selected objets. I eventually had to do them one at a time. Have you checked all the settings in the DATA TAGs insertion points?? Sometimes it might have some random value there that when you place them does this kind of behaviour? Quote Link to comment
Ramon PG Posted October 21, 2022 Author Share Posted October 21, 2022 14 hours ago, FBernardo said: Have you checked all the settings in the DATA TAGs insertion points?? Sometimes it might have some random value there that when you place them does this kind of behaviour? Thanks for the comment. I jumped from VWs 2017 to 2022 and did not try tags before. I found them confusing at first, but now I see their time-saving capability. I'll check on your suggestion. 1 Quote Link to comment
FBernardo Posted October 21, 2022 Share Posted October 21, 2022 53 minutes ago, Ramon PG said: Thanks for the comment. I jumped from VWs 2017 to 2022 and did not try tags before. I found them confusing at first, but now I see their time-saving capability. I'll check on your suggestion. Experiment with the tool, as it's quite powerful, I use it for doors, windows and walls... But it has so much more potential! 1 Quote Link to comment
