Anders Blomberg Posted October 14, 2022 Share Posted October 14, 2022 (edited) I seem to always struggle with georeferencing no matter how much I work with it 🙂 This time around the fault might actually be within VW 23 though but I just wanted to check with the forum first. I start out with 2 copies of the same file, both set up with the same/correct georeferencing settings. I have received a georeferenced DWG that I've imported into one of the files to create a shuttle file. The imported geometry sits right where it's supposed. The other file is intended as the master file, so I create a viewport for the shuttle file. This time around the geometry is way way of location, roughly by half a globe. Did the same thing in 2022 and here the geometry sits in the right location in both files. I know 23 has some GIS/referencing updates, so maybe my workflow is incorrect?  I attach some screenshots and the two files. NBK NY = shuttle, Björkhaga = master.  Might I call upon @Katarina Ollikainen for some help again?    Björkhaga.vwx NBK NY.vwx  Edited October 14, 2022 by Anders Blomberg Quote Link to comment
Vectorworks, Inc Employee Katarina Ollikainen Posted October 14, 2022 Vectorworks, Inc Employee Share Posted October 14, 2022 Hi Anders, I'm happy to help. There is an issue with the XML file for Sweden in the 2023 file and there is a fix for it. Unfortunately, it didn't make it in SP1 (it was found too late) but we have a workaround. Do you want to meet up on Zoom on Monday morning and I'll walk you through it? I'm actually going to Sweden this weekend, so I'll be in your time zone. Let me know and I'll send you a link. 2 Quote Link to comment
Alexander MA Posted January 12, 2023 Share Posted January 12, 2023 Hi @Katarina Ollikainen I think i'm having a similar issue - with one version of the same file located correctly, and the other way off.  When I import a DWG directly into my working file, it is located correctly. But when i convert that same file to a VWX and bring it into my working file through a viewport, I can't seem to get it to land correctly.  Any help would be super appreciated! Quote Link to comment
Vectorworks, Inc Employee Katarina Ollikainen Posted January 12, 2023 Vectorworks, Inc Employee Share Posted January 12, 2023 Hi @Alexander MA, If you post the files here (or you can send them directly to me, Kollikainen @vectorworks.net) I’ll take a look and come back to you. Best, Katarina Quote Link to comment
SarahMDI Posted March 3, 2023 Share Posted March 3, 2023 Hi all,  I am having the same issues with my viewport not geo referencing properly even though reference file itself is properly georeferenced. Did we find a solution for this? I'm using 2022.  Thanks! Quote Link to comment
