azizg 0 Posted September 10, 2004 I'm trying to render a model, I try to render using iether renderworks or open GL. instantly The programe behaves as if it has compleated the render, but only shows the checkered render background. When I zoom out there will reach a point of magnification where it will render correctly. But zoom back in and the same problem occurs. the problem occurs regardless of active layer or class. and regardless of which object is viewed. This only occurs in Orthogonal projection, not in perspective. The problem has appeared several times in different drawings usualy in files of more than 60MB. Once the problem effects a drawing the pattern of behaviour sticks with the drawing regardless of restarts. It occurs in VW11 and previously in VW10 Does any one have any ideas? This is annoying. Thanks Aziz Quote Share this post Link to post
