KIT KOLLMEYER Posted October 9, 2022 Share Posted October 9, 2022 I'm experiencing an issue with associative dimensioning in viewport annotation. I've always found dimensioning in viewports a bit inconsistent, but this morning I realized the exact issue: When a wall has any kind of complexity (like wall components T-joining to other wall components as you can see in the video below), associative dimensioning doesn't work with components inside a wall. This video shows the issue: https://www.loom.com/share/6ec1a3d596dc421e846e68bf6ebb5764 I have associative dimensioning turned on in document preferences, so it's not that. I'm hoping this is user error and someone sees where I'm failing. Thanks! Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted October 10, 2022 Vectorworks, Inc Employee Share Posted October 10, 2022 16 hours ago, KIT KOLLMEYER said: I'm experiencing an issue with associative dimensioning in viewport annotation. I've always found dimensioning in viewports a bit inconsistent, but this morning I realized the exact issue: When a wall has any kind of complexity (like wall components T-joining to other wall components as you can see in the video below), associative dimensioning doesn't work with components inside a wall. This video shows the issue: https://www.loom.com/share/6ec1a3d596dc421e846e68bf6ebb5764 I have associative dimensioning turned on in document preferences, so it's not that. I'm hoping this is user error and someone sees where I'm failing. Thanks! Can you PM me the file? Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted October 17, 2022 Vectorworks, Inc Employee Share Posted October 17, 2022 On 10/10/2022 at 9:53 AM, Matt Panzer said: Can you PM me the file? Hi Kit, I received your file (thank you) and here are my findings: This actually looks like a general problem with constrained dimensions. When a dimension is placed in the annotations constrained to an object from a design layer, it seems to work fine. However, as soon as I break the constraint by dragging one of the control points for a witness line away from the object, dragging the control point back to the object will not recreate the constraint. I don't see this problem when placing the dimensions directly on the design layer. Bug reported (VB-191058) Here's a short (silent) video of how I recreated the issue dimensioning to a wall or rectangle. First the video shows how it all works in the design layer (as expected) then it shows the bug when placing the dimensions in the viewport annotations. Thanks again for sending the file and helping me to recreate the problem! ScreenFlow.mp4 3 Quote Link to comment
KIT KOLLMEYER Posted October 18, 2022 Author Share Posted October 18, 2022 Thanks Matt, Wow, you're right. I was also able to recreate the same results. So until the bug is fixed, the solution is to only create new dimensions rather than make adjustments to existing dimension control points. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted October 18, 2022 Vectorworks, Inc Employee Share Posted October 18, 2022 2 hours ago, KIT KOLLMEYER said: Thanks Matt, Wow, you're right. I was also able to recreate the same results. So until the bug is fixed, the solution is to only create new dimensions rather than make adjustments to existing dimension control points. Yeah. Not great solution, I know. If I can come up with a better one, I'll let you know. At least we have an easily reproducible case. Hopefully this can be resolved soon. Quote Link to comment
