The Hamma Posted October 6, 2022 Share Posted October 6, 2022 Can anyone help me to connect these trusses in the possition they are in. File attached truss.vwx Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted October 6, 2022 Vectorworks, Inc Employee Share Posted October 6, 2022 Normally you could use a center point hinge or a truss corner symbol that has the appropriate angle, but your custom trusses do not match any of the standard truss sizes in the library (that I can find at least). Common sizes include 12", 15" and 20.5" box (or 30cm. 40cm and 50cm) If you have access to the Spotlight truss libraries look in them at the Tomcat libraries, they have several different sizes of center point hinge that should work if you are able to adjust the height and width of your custom trusses Quote Link to comment
