I am trying to create some schematic views showing these lights for the purposes of an accurate plot.
The top line of truss inserted with each truss swapped in the order. So instead of 1 2 3 4 5, the truss was ordered 5 4 3 2 1. The second line of truss I can't even figure out what it's doing. Despite selecting "Front" in the dialog box, two of the three schematic view objects are set to "Rear", and they've also somehow rotated such that I can't get the cross bracing on the truss to be correct. Not to mention that one is appearing above the other two. Some lights (but not others) appear to be hung on the top chord of truss, despite them all being aligned perfectly.
I haven't even tried the bottom set of truss.
This seems like possibly the simplest use case scenario for this tool. Just a line of truss with some lights. No fancy raking or strange lighting positions that should throw the tool into the tizzy it's apparently in. I've tried messing with selection order, deleting all the hoists so the truss system isn't connected, making sure I'm in Top / plan view.
Craig Rutherford
Have a look at these two screenshots.
0 answers to this question
