ryanesson Posted October 3, 2022 Share Posted October 3, 2022 Hi all, I've put this in 'workflows' as it seemed the most logical - however apologies if the wrong place. I do set designs for a client that request the use of plants and foliage in the design which having played with plant insertion I am struggling to represent in vectorworks. For example - I want to create truss rings that are dressed with foliage - see attached image - but I struggle to add the plants in VW and get it looking right. The plants I insert are typically image props and oversized for the purposes that I want to use. As I usually try to use multiple to create the fullness they create some weird artifacts when rendering when they foul each other. They typically also can't be rotated due to being hybrid symbols if I want to reorientate them. I am reasonably proficient on VW but haven't ever really used the foliage/plant elements before so would appreciate any tips or workflow suggestions. Quote Link to comment
Tom W. Posted October 3, 2022 Share Posted October 3, 2022 See this thread re Foliage Tool Should be able to achieve what you want with it just need to play with different configurations Quote Link to comment
ryanesson Posted October 4, 2022 Author Share Posted October 4, 2022 Thank you Tom. Very helpful. Ryan Quote Link to comment
