Ben3B Posted September 27, 2022 Share Posted September 27, 2022 (edited) Hello I've a project with the venue as vwx referenced file, And there appear at top view instead of 2dplan view . everything works well in the original file file referenced project with the referenced file who appears in top view (5) Edited September 27, 2022 by Ben59 Quote Link to comment
Hans-Olav Posted September 29, 2022 Share Posted September 29, 2022 Is it a DesignLayer viewport or are you using Layer Referencing? In your target file you should be able to change between top/plan or 3d views. Quote Link to comment
Ben3B Posted September 29, 2022 Author Share Posted September 29, 2022 1 hour ago, Hans-Olav said: Is it a DesignLayer viewport or are you using Layer Referencing? Hello thanks for answer, I'm not sur too understand your quetion ... it is a referenced viewport with an extern target VWX file. Is there many way to do that ? I created a new viewport on an existing design layer, and choose an external ref. I saved the external file in topplan Quote Link to comment
Hans-Olav Posted September 29, 2022 Share Posted September 29, 2022 Check the layer where the viewport are located. That layer needs to be in top / plan too It is also possible to reference some or all layer to yo file They will behave as normal layers but locked Quote Link to comment
Ben3B Posted September 29, 2022 Author Share Posted September 29, 2022 On the toher layer I can select some option as the view (an arrow appear when my mouse is over it ...) but nothing happend for the layer with the viewport and the referenced file Quote Link to comment
Hans-Olav Posted September 29, 2022 Share Posted September 29, 2022 try to make the layer active and set the layer to top plan from there Quote Link to comment
Ben3B Posted October 13, 2022 Author Share Posted October 13, 2022 Even i 'm "active only" in top plan view , the referenced is in top view (not topplan) Quote Link to comment
Tom W. Posted October 13, 2022 Share Posted October 13, 2022 On 9/29/2022 at 2:49 PM, Ben59 said: On the toher layer I can select some option as the view (an arrow appear when my mouse is over it ...) but nothing happend for the layer with the viewport and the referenced file @Ben59 this seems similar to something I experienced. See: My referenced DLVP would not display the 2D (Top/Plan) component if the source file had been saved in a 3D view. But it wasn't a consistent problem, it just happened to me once. I deleted the reference, resaved the source file in Top/Plan view + recreated the referenced DLVP + all was fine again. I wondered whether it was a VW2022 problem but you seem to be on VW2021 so perhaps not. Quote Link to comment
Ben3B Posted October 13, 2022 Author Share Posted October 13, 2022 Hello i'm on 2022 (because Im french Ive to wait until october 25 for V23...) Ok so it's like a Bug ? I ll already try to save it in 2Dplot but without good result... Ill try to delete and import it back ... Ill let you know Quote Link to comment
Ben3B Posted October 13, 2022 Author Share Posted October 13, 2022 in a new file it works , and if I delete and redo the import, it works... 2022-10-13 13-48-43.mkv 1 Quote Link to comment
Tom W. Posted October 13, 2022 Share Posted October 13, 2022 Ok cool glad you got it sorted 1 Quote Link to comment
