Section Viewport NOT rendering correctly after Image Shader Texture was updated.
Section Viewport - Crop / Annotations / Rendering were all set. Tested - worked - looked as expected.
One symbol in the drawing & the viewport was a Monitor with a generic texture applied for the screen image.
This texture was updated with a revised image shader. Same texture was used, It was already applied correctly, and nothing else was changed.
Viewport renders as expected, except it will no longer show the Monitor with a screen image.
¿ Why is the question ?
Other NON Viewport rendering of this monitor work correctly. (The preview in the Resource Manager is one of those suspect Grey Gradient vs a real image)
Solution, after playing with the Image & Shader was to place a 2D image over the monitor in Annotations section of the Section Viewport.
Elite Exhibits
Suggestions are always welcome.
VW 2020 SP6 (Build 528704) (64bit)
MacBok Pro M1 Max
OS 12.51
User since MiniCad +
Peter
Blank Render.pdf
0 answers to this question
