Search the HELP file with Google or ?
Elite Exhibits
Is there a better way to search the HELP file...  with Google or ?
Searching has long been a painful issue with VW Help
Some times it is great ! …sometimes there is nothing ?
    Potentially, the fail is based on looking for a topic, NOT in the HELP file to begin with.
When coming up short, I typically use the Google “site” trick searching as …
site:https://forum.vectorworks.net - site:https://techboard.vectorworks.net - etcetera
The question is -
¿ Is there a way to, with Google or (?), search directly in the VW/RW HELP that is associated with your current version ?
Why I ask ...
Searching recently in the VW / RW HELP (2020) for “Retrieving Object Names in Worksheets” was with out success.
A hit, though, was returned utilizing “Retrieving object names in worksheets” site:https://forum.vectorworks.net for a 2008 post, by Markus Barrera-Kolb. (However, this post did NOT have the desired chart of designations & a broken link to helpful cheat sheet)
Where I did find information was in an old VW 2016 (¿User Guide?) in a PDF, on a back up hard drive. (Thanks to consistent backing up & to the search function on the Macintosh.)
Suggestions are always welcome.
VW 2020 SP6 (Build 528704) (64bit)
MacBok Pro M1 Max
OS 12.51
User since MiniCad +
Peter
Search for.pdf
5 answers to this question
The full list of Worksheet Functions is available at:
https://developer.vectorworks.net/index.php?title=Worksheet_Functions
I am not sure if this list includes the "criteria like" functions:
Object Name (=N)
Object Layer (=L)
Object Class (=C)
These (and maybe others) are referenced in the Vectorscript Appendix E.
https://developer.vectorworks.net/index.php/VS:Function_Reference_Appendix_E
In case you indeed want to use Google to search the Help files, I believe it should work if you use the following URL (I've only tested briefly...)
[keywords] site:app-help.vectorworks.net/2023/
No clue how may versions back this URL syntax goes...
Thanks for posting that ! Well it works in 2018; site:app-help.vectorworks.net/2018/
I too usually search from site: , but had no idea of app-help
For faster searching / non-text don't forget to use google images.
