Tasfire
white walls show as dark gray
I am having a problem with my drawing that wasn't happening yesterday. My white walls are showing up gray/dark gray when I use Renderworks. I have multiply light sources shining right on them and they are still dark, but all the other light colored objects are the right amount of lightness. When I use openGL everything is a blinding light because of the light sources. Why does Renderworks make my white walls dark? I even tried making them slightly reflective but that doesn't help at all. I'd appreciate any advice. [smile]
Make sure you didn't accidentally duplicate the walls. Duplicate objects on top of one another will cause some strangeness while rendering.
Good Luck
Hello Tasfire:
Also check to make sure that the lights aren't being shadowed by geometry, if they are close to some object surfaces.
If you send me the file I can try to figure it out.
We used to have a problem when turning on the black background. Some objects that had a "pure" white filling turned black in the rendering. This happened in VW 9. Now we just use a black background with our renderings. I don't know if you have the same problem. You could also try to fill the walls with a slightly offset white. ie. 255,255,254. Maybe this helpes?
Thank you all! (Dave - the file is too large to email, I tried emailing it when it was half this size and it didn't make it. Thanks anyway.)
