spries Posted September 20, 2022 Share Posted September 20, 2022 (edited) I made a poly line, extruded it, and as a fill I applied a gradient. However, it doesn't show the gradient when shading. What am I missing? Thanks for any help. gradient test v2022.vwx Edited September 20, 2022 by spries Quote Link to comment
0 Tom W. Posted September 20, 2022 Share Posted September 20, 2022 Gradients Fills can only be applied to 2D objects 1 Quote Link to comment
0 markdd Posted September 20, 2022 Share Posted September 20, 2022 Gradients attributes can only be applied to 2D objects. If you want a gradient effect for this 3D object, then you will need to make a specific texture resource with a gradient image loaded in the Color shader. 1 Quote Link to comment
0 spries Posted September 20, 2022 Author Share Posted September 20, 2022 3 minutes ago, markdd said: Gradients attributes can only be applied to 2D objects. If you want a gradient effect for this 3D object, then you will need to make a specific texture resource with a gradient image loaded in the Color shader. Is there a way to convert it into a 2D shape? if so, which one? Quote Link to comment
0 markdd Posted September 20, 2022 Share Posted September 20, 2022 What do you want to convert? Quote Link to comment
spries
Edited by spriesLink to comment
4 answers to this question
