show gobo in shaded?
fuberator
The gobo wheel tab is only used for specifying, overriding the default load, which gobos are in the gobo wheel for Vision exports since you can select the gobo using a console.
Since Vectorworks can't process DMX data from a console you need to specify which gobo will be used in the Light Information tab by selecting a gobo texture resource.Screen Shot 2022-09-16 at 1.27.38 PM.png
Vectorworks 2023:
I found that I needed to push a shutter in slightly to make gobos visible in Shaded views.
Just 1% seemed to make all the difference.
Then I set the Data Visualisation to "None" and all of a sudden I could see the gobos i the beams and on surfaces, and the colour for the beams as well.
I pulled the shutter back out and the gobos and colours continue to work.
It seems as if the Data Visualisation that I was using ("Grey Lights" so that I could see the fixtures more easily to select them) was overriding the gobo and colour settings.
I hope this may help you.
John
John Bishop
John Bishop Lighting Design
