Problem with Texture libraries
JMLit
I have just started using Vectorworks and I am having trouble using textures. When I go to the texture libraries and choose a texture, the symbols that appear in the resource browser are not there, and if they are the are spherical shapes with small dimples on them. If I apply the texture to a wall and render it the drawing either comes up all white or sometimes grey. Any suggestions??
If the drawing is all white, you may have too many lights; gray may be due to no lights, or the light orientaion not pointing towards the object properly.
Also, make sure the objects you are applying the texture to have a solid fill.
Can you please clarify "the symbols that appear in the resource browser are not there, and if they are the are spherical shapes with small dimples on them"?
Thanks
