C4D Plug-in
MacDaid
  • 3 weeks later...
Hi Chuck
Guess it would be too much to ask the tech people to reply as this is about exporting your VW drawing into Cinema 4D to render it, thus not using Renderworks.
The plug in allows you to export the file in a format recognised by Cinema 4D. Once in Cinema you can render, apply materials, animation etc. all the usual stuff.
What it also allows is for updating - but only in one direction, the important one! Any changes you make to the VW file can then be exported as an update to the Cinema file which will keep all the details you have worked on but also update to reflect the VW file.
It's a similiar plug in to the Artlantis one, made by the same people in fact.
Go to Maxon web site for more details - http://maxon.net/index_e.html
Look in the left hand side bar you'll see Vectorworks in the solutions.
Regards
Alan
Chuck D,
This plug-in works pretty well. I have used it several times. It works off of class colors to differentiate between objects. We sell the CD here I believe if you wanted to get a copy.
  • 1 month later...
