holstarc
Image Props
i'm creating image props of people in an interior environment, but unfortunatley those pesky 3d locus points keep showing up at their feet, is their a way to turn those off when you render.
Thanks
Kevin
G4 350mhz, 1.12g of ram, VW/RW 10.1.2
I don't know how to turn them off either, but they do dissapear if you export 'current view' to an image file. At least on 10.5
[ 12-16-2003, 12:41 PM: Message edited by: Becki ]
Thats's interesting, i guess i assumed since i saw it on the screen it would be there on export....I'll have to try a quick batch render.
Thanks becki.
kevin
[ 12-16-2003, 12:50 PM: Message edited by: holstarc ]
Hello:
The loci will not be visible with printing, image export, or rendered bitmaps. They are only visible onscreen.
We will be removing them in a future release. They are there so that you have a snap point available; otherwise the smart cursor wouldn't snap to the bottom center of the prop. We can remove the loci by adding an extra vertex at the bottom center of the prop polygon which will give you the snap point.
