Problems with overlapping image props
Becki
Any idea why those grey boxes are showing up where the image props overlap? (v. 10.5) It seems to be only where the the same prop overlaps itself, otherwise everything would be grey because of the tree prop.
It looks like it's only showing up in elevation and perspective views, I haven't had any problems with it in isometric yet.
Thanks!
[ 12-11-2003, 06:05 PM: Message edited by: Becki ]
Final Quality RW mode uses a recursion level of 5, so that explains why that mode works.
Each surface will require 2 levels of recursion, one for the front side and one for the backside, so if you have 4 overlapping props you will need to set the recursion to 8.
Note that the upper limit is currently 9, but we will be lifting this restriction in a future release just in case you need more.
HTH,
