Henry Finch
floor objects should have 3 textures
Floor objects should have 3 texture choices like walls.
- A floor texture where you could use carpet or wood for example.
- A ceiling texture which would probably be white in most cases.
- An edge texture which could be the exterior wall texture.
I have always used a narrow wall going around floors to get the right exterior wall texture on the model. When I wanted a floor texture I add a thin 3D object on top of the floor. Floor objects having 3 textures would make modelling faster.
sorry if this discussion took place before. I seem to remember it a few years ago.
Henry
mac G4 1.25 dual, OS10.2.8, VWA&R 10.1.2
vectordepot has a free 'slab' plugin that does exactly what youre asking for [smile]
u simply draw a polygon with the slab tool, u set its thickness and z height and it has separate classes for floor, ceiling and edges
