DSmith2300 Posted August 30, 2022 Share Posted August 30, 2022 Frequently on the sheet view when zooming or moving, the screen does this freak-out before settling down after the mouse button is released. Is this a bonus feature within VW2022 or some merely quirkiness of my particular GPU interaction? If the later, could anyone suggest a particular setting which I might tweak to get rid or minimise of this? Many thanks Quote Link to comment
fabrica Posted August 30, 2022 Share Posted August 30, 2022 I get this also - no solutions I know of.... (hatching seems to be FU in 2022) 1 Quote Link to comment
Pat Stanford Posted August 30, 2022 Share Posted August 30, 2022 Check and see if your drawing is located a long way from the User Origin. If so, you need to take a look at the Georeferencing options to move the drawing closer to the drawing center but still be able to display the correct location/dimensions. The accuracy of drawing is poor when you are a very long way from the origin. Anything more than a few kilometers (I vaguely remember someone saying 15km one time) can cause this kind of rendering artifacts. Quote Link to comment
fabrica Posted August 31, 2022 Share Posted August 31, 2022 for me, most of the whackiness is in annotation viewports using hatches. The settings seem so messed up compared to 2021, even zooming in and out will cause it to flicker (and lag) and go mad.... the scale of hatches when first used in 2022 seems to be off v. 2021 and it scales back to and forth each zoom (if that makes sense!) This is on both an intel iMac and M1 Mac Pro Quote Link to comment
Pat Stanford Posted August 31, 2022 Share Posted August 31, 2022 Sound like a far from origin problem. If you can't find the issue, post the file (or DM it to me) and we can take a look. Quote Link to comment
jeff prince Posted August 31, 2022 Share Posted August 31, 2022 I have recently experienced this on a windows machine in 2022. The file has some aerial photography and various 2D CAD illustrations floating over the aerial. It started happening as the page count increased and a corresponding increase in the file’s total viewport count. I’ve seen similar in 3D, but not 2D until using 2022. Maybe this anecdotal evidence will help figure it out 🙂 I’ll have to open it on my Mac and see if the behavior is replicated. Quote Link to comment
fabrica Posted August 31, 2022 Share Posted August 31, 2022 the hatch units were set to world not page... seems to be much smoother now! 1 Quote Link to comment
LarryO Posted September 1, 2022 Share Posted September 1, 2022 This happens in my work too, generally when there is a complicated viewport on a sheet, the page based symbols on the sheet freak out. Usually the graphic in our title block is the most distorted part. Save the file, then Revert to Saved resets it to normal. 1 Quote Link to comment
LarryO Posted September 2, 2022 Share Posted September 2, 2022 Not so complicated viewport in this instance. I placed our marker symbol which is page based and that triggered the glitch. Note that the titleblock is also page based. The plugin script places the symbol and then collects and manages the text. Saving and reverting to saved will remove the ghost and fix the glitch which I am unable to capture using the basic screen capture method of Win 10. Send me a PM if you think a copy of the file could be of assistance. VW build 653494 Quote Link to comment
DSmith2300 Posted September 6, 2022 Author Share Posted September 6, 2022 Thanks all. I'll try the 'revert to saved trick' next time it freaks out. Quote Link to comment
