ODBC Drivers / Purpose
@jeff prince@unearthed
I'll do some experiments, stay tuned!
But here is the summary of what I've discovered so far (on a local level)
When using an sqlite file, I modify the sqlite file in an open source sqlite file editor - something like
https://sqlitestudio.pl/
I add tables to it specifically to what I need (I.E. product database with insulation characteristics, or pricing tables, or zoning / building code reference database and I link the database to record information in VW in read only mode.
When i assign that record to an object - it does not update immediately, i have to use the update vectorworks database in order for it to choose. The table above was an experiment of sqlite database reference - and in large databases, a search query or search by record would be fundamental to using ODBC.
The part that is annoying is that I can change a record in the sqlite file upon entering the information, but I cannot update the object upon selecting the record, which is a bit frustrating.
I'll try using ODBC with mysql hosted on a local docker vm and update my progress soon.
Edited by Samuel Derenboim
Bonjour Samuel,
J'ai fait quelques tests simples sur des fichiers SQLite il y a un mois.
Le test simple était de modifier le fichier SQLite et de récupérer les données modifiées dans Vector, ça fonctionnait pour les données de l'onglet "Info Objet" comme le prix ou la référence.
Je ne suis pas allé plus loin pour l'instant mais suis intéressé par ce sujet!
Bon test!
great news everyone, ODBC works for mssql . however I am missing something. I am still getting an error after setting up a connection after successful test via ODBC.
I used MS SQL server 2019. Am i to use an earlier version?
 I was able to set up a table inside the container and was able to connect via test connection when setting up ODBC parameters.
after setting up the connection - i get this error
Note - I have confirmed the sql tables work via noco database, so the problem lies with either the driver, sql version number, or something else. (see screenshot below)
connection currently works, i just don't know why it rejects the connection after successful test.
UPDATE 3
When you start stacking up with the ODBC datasources, you still need to delete the ones that do not work.
Go into administrative tools and ODBC Data sources and remove any data sources you do not need.
Also, if you want to set up new datasources flexibly without VECTORWORKS, this is the way to do it! In vectorworks you cannot modify existing ODBC databases. Here you can.
I think that connected data bases are one of the most underutilised features. We still do a lot of 2d projects and the floorplans and views are seperate files, so I used a sqlite table to syncronise the record for our window symbols. Only one colleague had to update the information in the floor plan and the data tags in the view file was updated accordingly. Huge time saver.
@elepp
I agree . Great potential.
I'll start another post later, but combing this with a web gui remotely will sky rocket it's potential.
May I ask, what do you use it for in particular ? Sorry about that, too early in the morning, didn't see you mention you used it for windows.
Do window sizes auto update upon selection of the record?
And can you lookup database tables to cross reference records in a worksheet? ( it's a topic I will start a new post on soon )
Hi, that project was done with 2d symbols, because the windows were to complicated to generate with the vectorworks window tool.
I didn't manage to play more with the functions, we used it mainly to shift the data from file a into file b.
I see a bit of potential for facility management with a data base you are setting up. The main tool would be the data base and Vectoworks would be for visualising the data in the floorplan. Like cleaning schedules or seating plans.
  • 1 month later...
Try installing the latest mysql 8 odbc driver. The native one doesn't work, had similar issues. Also, use the universal driver rather than ansi
Also note that you can actually access the database and have your password and login correctly
I dont have Mac unfortunately, can't test it.
@GatRed
Are you running a mysql server? does it work via phpmyadmin? or similar? Have you created a database table inside the server? did you install the latest odbc driver for mac? Can you show us a screenshot of your DB connector window?
FYI
https://dev.mysql.com/downloads/connector/odbc/
Use the driver to connect to your database first. If it connects, you will be able to use it in VW. See above posts for referencing db info into VW
Also, once you confirm connection via outside source (i.e. self hosted http access), try this connection (it should work the same, system independent)
DSN=MYSQL_Uni;UID=sa;PWD=password;
DSN : Driver name for mysql after you install it
UID : Username (often its root, but if you create a separate user to access the db table, you can use that)
PWD=password for username to access database table
Hi @Samuel Derenboim,
Thanks for your feedback.
Here are more informations :
1. I installed MariaDB and phpmyadmin on a Synology NAS
230776505_Capturedcran2022-10-1210_20_10.thumb.png.d10551d8a459a90ac5dab233e6ca30c2.png
2. I create within phpmyadmin a user 'gaetan' an a database 'Vectorworks_DB' with all access.
1520778108_Capturedcran2022-10-1210_23_10.thumb.png.435420140c830223b81176f12b5e98eb.png
3. Using iODBC Connector, I created a user DSN and manage to do the test
4. But within Vectorworks, when a do the connection, I’ve got the following error message :
[1049] Driver error: S1000 [MySQL][ODBC 8.0(w) Driver]Unknown database 'null'
1635021434_Capturedcran2022-10-1210_26_46.png.e6cf4e6d7fc7fd8bdad5c90a4bd6a124.png617026296_Capturedcran2022-10-1210_27_09.png.2fe24a5c1fa16b092889eb00e1ff26b5.png
I think I did something wrong within myphpadmin, but I don’t know what…
In addition, I manage to connect and edit the database with a third party application like Sequel Ace.
71001004_Capturedcran2022-10-1212_11_27.thumb.png.7e5362692c13759a56ac940a66c9d946.png
If you know what is happening, I would be really grateful.
Edited by GatRed
Your dsn appears to be Gramysql not odbc 8.0 there error show that it cannot find the driver name. They have to match.
Additionally since you populated it in your iodbx driver, it might not be necessary to enter it into vw. Repopulate available databases in the first table where you load the database. Gramysql should be there.
Here are all the screenshots of the error using the mysql driver and mariaDB, the last one is shown when clicking on "Details…".
I tried with the MariaDB ODBC Connector. I had to install Homebrew and openssl via Terminal commands also.
But then, I get this error while making the test with iODBC :
PS : I use MariaDB because it is available as a package on Synology DSM system, whereas it is not for MySQL.
Edited by GatRed
it seems mariadb is not supported
https://app-help.vectorworks.net/2023/eng/VW2023_Guide/Database/ODBC_driver_information.htm
https://mariushosting.com/how-to-install-mysql-on-your-synology-nas/
Just FYI, I started out with a Synology NAS as well, but after a certain point it became too limited for hosting options, which is why I learned to use Docker.
OK,
So I uninstalled MariaDB and phpmyadmin packages on my Synology.
And I installed Dockers images of mysql and phpmyadmin.
1197966045_Capturedcran2022-10-1221_58_44.thumb.png.d4f5d705836bcfeb80f4c0dcb521933a.png863172575_Capturedcran2022-10-1221_58_36.thumb.png.782a7df0bdaf836db43b7c1b0bd07a88.png
Connection with iODBC is OK.
Acces with Sequel Ace is also OK.1476848470_Capturedcran2022-10-1222_00_43.thumb.png.1ebdaf9273c26ad10baf6ed9c8afd1e2.png
But within Vectorworks, I’ve still got this error Unkown database 'null'.
1459156487_Capturedcran2022-10-1222_01_05.png.d06b030d7a2f45d6d3fa01c10444811e.png994721963_Capturedcran2022-10-1222_01_08.png.a2a46b4db2ba38a0c71a9bf193197229.png537482240_Capturedcran2022-10-1222_01_14.png.c78210f6d09ef6d2417358e566f5b32d.png
Any Idea ?
If I manage to make it, I promise, I will do a tutorial.
what version of mysql is it? can you post the docker / docker compose script? Also, try playing with the settings of the mysql driver. They also have 2 drivers, 1 uni and 1 ansi. maybe the ansi one works better on mac?
Also, as an experiment, try recreating another connection via iodbc driver. There are also certain options you can use in the connection, maybe there is something in the settings that is in conflict with VW
Thanks @Samuel Derenboim for your help.
I think you’re on of the few people who are using the database link future in Vectorworks.
I’m starting to understand why, as it is so difficult to set up…
In tried to create another DSN, to use the Ansi driver, etc. but without any different result : always the same error.
Here is a screenshot of the mysql server version : 8.0.31-1.el8
862161887_Capturedcran2022-10-1310_37_45.thumb.png.1e4050b2629300eafde478f2fdf80e41.png
I think I’m going to give up…
if anyone manage to find how to set up this on a mac……
