Datatag - MATPROPERTYBYNAME(WS_Material, 'MaterialDescription')
Will we ever be able to pull material data information into a data tag?
I noticed in order to pull it in a worksheet - command is something like :
=MATPROPERTYBYNAME(B3, 'MaterialDescription')
=MATPROPERTYBYNAME(B3, 'MaterialReferenceID')
=MATPROPERTYBYNAME(B3, 'MaterialManufacturer')
etc...
Will we be ever able to do the same thing with data tags?
3 hours ago, Tom W. said:
@Samuel Derenboim see:
Can be used to tag materialmanufacturer, materialreferenceID, etc as well. Unless it's a Compound Material in which case you can only return the Description, Mark + Keynote fields as far as I can tell
Thank you for letting me know! Posted a formula for regular geometry as well.
Will be very useful in the future for detail call outs (creating a custom set). Originally intended on using symbols with custom records for annotation and callouts.
I also noticed a custom record option in materials - it would be interesting to see how that works as well! I will keep experimenting
Edited by Samuel Derenboim
