Hunter B Posted June 24, 2003 Share Posted June 24, 2003 I want to create an animation that starts with the ground plan and then drops into the room and rotates toward a presnter at a lectrun. I almost have it but I need to be able to see the ceiling from the "inside" of the room but I need to see thru the celing when I'm looking at the ground plan of the room. Is there a way to get the ceiling to be tranparent from the top but opaque once I'm under it??? does this make sense? or how can I swith off the ceiling in one sheet and turn in back on in another? Quote Link to comment
Kaare Baekgaard Posted July 3, 2003 Share Posted July 3, 2003 Try out AnimationWorks from OzCAD. Its simple, inexpensive and good, and it will do the trick. Quote Link to comment
