Hunter B Posted June 24, 2003 Share Posted June 24, 2003 OK so I got most of my bugs worked out when rending a walk thru... so I have a couple of questions.... I start with a ground plan view, normal perspective. I then raise the Ground plane and rotate the view and save the sheet. I then again raise the Ground plane rotate the view some more and then again same the new sheet, I again raise the Ground Plane so that my point of view is 48" and rotate to look toward the object I want to come to rest on..... so far so good. I then create the animation as usual and link the sheets together to create the movie...BUT...between the first two view it does not flow... it jumps.... Does anybody know how to fix this?? Quote Link to comment
