Data Tag Box Auto Width?
trashcan
8 answers to this question
7 hours ago, Mark Aceto said:
ok i finally get it now
it's one poly for the entire data tag (almost like a crop object for a viewport)
54011121_ScreenShot2022-08-18at6_18_34PM.thumb.png.1ec3192fc07a5f399ef3be3acb364b39.png210365249_ScreenShot2022-08-18at6_18_52PM.thumb.png.a7c3fcf86507f05da9b9ecc438d73a6f.png
Well you can have multiple polys but the constraints are to a boundary that VW places around all of the geometry so you can't constrain individual text objects to individual polygons.
So you can do this:
687144268_Screenshot2022-08-19at07_02_57.thumb.png.c2c9dcaa631925252415cd3b26b26f4c.png
But can't as far as I know have the rectangles varying widths depending on the amount of text in each field.
BTW did you know about the Tools > Create Data Tag Style... command? I didn't until a couple of weeks ago. This allows you to create a tag directly from an object so might be useful in your case where you want to list lots of parameters + put boxes around the text. You can then tweak the constraints to get the same thing as in the above screenshot:
Very quick + easy way to generate a certain type of data tag + new with VW2022.
One of the best-kept secrets by the VW marketing dept. Think it’s actually been around since 2021 but the command had to be manually added to your workspace.
I use it for all the data tags that I’ve been gradually adding to my user library. I always check both columns to create labels. Continuing to build… continuity… across all data tag styles.
