Kevin Posted June 19, 2003 Share Posted June 19, 2003 Under VW9.5.3 with Renderworks and OS10.2.5 while doing a "Convert Copy to Lines" the program freezes. it stops rendering and i get the spinning beach ball. Computer has 1024MB of memory, processor is G4/1Ghz. Freeze occurs before and after a computer restart. I have the number of undo's set to 1. The file size is 46MB. it was frustrating enough not being able to do an orbit point annimation, but now I cannot even generate an exterior elevation sheet for the working drawings. This was a topic on this board before. The final post was that NNA engineers would look into it. Has a solution been found? Quote Link to comment
Kurt Magness Posted June 19, 2003 Share Posted June 19, 2003 Have you tried running the disk utlity program to fix & verify disk permissions? I have one computer that freezes alot and that seems to help. Kurt Quote Link to comment
Kevin Posted June 19, 2003 Author Share Posted June 19, 2003 Thanks Kurt. That is a good idea. Yes that is the first thing I did. I quit all programs and ran the disk utility, first aid. Unfortunately that did not solve the problem. Quote Link to comment
Kevin Posted June 20, 2003 Author Share Posted June 20, 2003 Hi Kurt. Thanks for the input. I may do that as a last resort. Other people have had this problem and Katie said that the engineers would look at it. I am anxious to hear the outcome of that investigation. I know that with the animation there is a bug. I don't know if this is the same. Quote Link to comment
Kurt Magness Posted June 21, 2003 Share Posted June 21, 2003 How about re-installing VWKS ? Quote Link to comment
