John Roloff Posted May 29, 2003 Share Posted May 29, 2003 Upon double clicking a texture such as VWAL_metals.mcd > textures > expanded, (that I brought in as a favorite to the Resource palette) to apply to an object in the Object Info. palette, I consistently get the following error message: The Record Format for Plug-in Objects named "NNAPhong" cannot replace the existing regular Record Format with that name, and these cannot be renamed. the entire operation is cancelled. I can use textures I made my self in the Resources palette but can't seem to use the VW ones. Thanks. Quote Link to comment
Guest Posted May 29, 2003 Share Posted May 29, 2003 UPdate your version of VW to 10.0.1 to fix the problem. While you are at it, you should update to VW 10.1 and 10.1.2 as well. Katie Quote Link to comment
