sjm_htc Posted August 15, 2022 Share Posted August 15, 2022 Hi all, I am trying to adapt a node I found on the forum which changes sheet layer sheet titles. I wish to adapt it to change sheet layer sheet numbers. What I have tried is to change 'object property index' from 159=Sheet Title to 158 which I hope is for the sheet number. I also changed the parameter from self.Params.sTitle.Value to self.Params.sNum.Value. Which I hope is the parameter name for the sheet layer sheet number. I think both are incorrect. I have uploaded a test file where I am trying to create this node. Below is the code I am trying to hack together to create the custom node for changing sheet layer sheet number. #Created by MFarrell 02/02/18 #modified to sheet number sjm 12.08.2022 @Marionette.NodeDefinition class Params(metaclass = Marionette.OrderedClass): #APPEARANCE #Name this = Marionette.Node( 'Change Sheet Number' ) this.SetDescription( 'Changes the Description value of a Sheet Layer' ) #Input Ports obj = Marionette.PortIn( vs.Handle( 0 ), 'hLayer' ) obj.SetDescription( "The input object" ) sNum = Marionette.PortIn( '' ) sNum.SetDescription( "Number of the sheet" ) #OIP Controls #Output Ports value = Marionette.PortOut('hLayer') value.SetDescription( "Handle to the layer" ) #BEHAVIOR def RunNode(self): #inputs obj = self.Params.obj.value index = 158 sNum = self.Params.sNumber.value #script value = vs.SetObjectVariableString(obj, index, sNum) #outputs self.Params.value.value = obj Batch Change Sheet Numbers_#2.vwx Quote Link to comment
michaelk Posted August 15, 2022 Share Posted August 15, 2022 I wrote one of those myself using VectorScript. It seems it would be super useful. 🙂 Are you trying to change the stacking order or the sheet number? Changing the stacking order is tricky. In VS the command is just SetName(). If I remember the number is actually the name in VS. The sheet title is SetObjectVariableString (layerHandle,159,'Sheet Name'); This might be helpful: {Badly scripted by Michael Klaers} {March 2020} PROCEDURE RenumberSheetLayers; VAR LayerInQuestion :HANDLE; LyrTypInt, Counter, StackOrderBegin, StackOrderEnd, RenumStart, RenumCount, HowManyLayers, NumDesignLayers, id, item : INTEGER; SheetPrefix, SheetSuffix, NewName, TempString : STRING; Bool :BOOLEAN; {******************************** The ever confusing dialog handler ****************} PROCEDURE Dialog_Handler(VAR item :LONGINT; data :LONGINT); BEGIN CASE item OF SetupDialogC: BEGIN Bool := GetSavedSetting('SLRename','StackOrderBegin',TempString); SetEditInteger(id,6,Str2Num(TempString)); Bool := GetSavedSetting('SLRename','StackOrderEnd',TempString); SetEditInteger(id,7,Str2Num(TempString)); Bool := GetSavedSetting('SLRename','SheetPrefix',TempString); SetItemText(id,12,TempString); Bool := GetSavedSetting('SLRename','RenumStart',TempString); SetEditInteger(id,13,Str2Num(TempString)); Bool := GetSavedSetting('SLRename','SheetSuffix',TempString); SetItemText(id,14,TempString); END; 1: BEGIN Bool := GetEditInteger(id,6,StackOrderBegin); Bool := GetEditInteger(id,7,StackOrderEnd); GetItemText(id,12,SheetPrefix); Bool := GetEditInteger(id,13,RenumStart); GetItemText(id,14,SheetSuffix); END; 2: BEGIN END; END; {Case} END; {Dialog Handler} {******************************** The slightly less confusing dialog layout ****************} PROCEDURE MakeMeADialogBox; BEGIN id:=CreateLayout('Renumber Sheet Layers',TRUE,'OK','Never Mind'); CreateStaticText(id,4,'First',-1); CreateStaticText(id,5,'Last',-1); CreateEditInteger(id,6,1,6); CreateEditInteger(id,7,1,6); CreateStaticText(id,9,'Prefix',-1); CreateStaticText(id,10,'Num',-1); CreateStaticText(id,11,'Suffix',-1); CreateEditText(id,12,'A',6); CreateEditInteger(id,13,0,6); CreateEditText(id,14,'',6); SetFirstLayoutItem(id,4); SetRightItem(id,4,6,0,0); SetBelowItem(id,4,5,0,0); SetRightItem(id,5,7,0,0); SetBelowItem(id,5,9,0,0); SetRightItem(id,9,10,1,0); SetRightITem(id,10,11,2,0); SetBelowItem(id,9,12,0,0); SetBelowItem(id,10,13,0,0); SetBelowItem(id,11,14,0,0); SetHelpText(id,4,'Stacking order of first sheet to be renumbered'); SetHelpText(id,6,'Stacking order of first sheet to be renumbered'); SetHelpText(id,5,'Stacking order of last sheet to be renumbered'); SetHelpText(id,7,'Stacking order of last sheet to be renumbered'); SetHelpText(id,9,'New prefix for renamed sheet layers'); SetHelpText(id,12,'New prefix for renamed sheet layers'); SetHelpText(id,10,'New starting number for renamed sheet layers'); SetHelpText(id,13,'New starting number for renamed sheet layers'); SetHelpText(id,11,'New suffix for renamed sheet layers'); SetHelpText(id,14,'New suffix for renamed sheet layers'); END; BEGIN {**** MAIN ****} MakeMeADialogBox; item := RunLayoutDialog(id, Dialog_Handler); IF item = 1 THEN BEGIN {MESSAGE ('Stacking Begin: ',StackOrderBegin,CHR(13), 'Stacking End: ',StackOrderEnd,CHR(13), 'Prefix: ',SheetPrefix,CHR(13), 'RenumStart: ',RenumStart,CHR(13), 'Suffix: ',SheetSuffix);} Counter := 1; LayerInQuestion:=FLayer; HowManyLayers := NumLayers; RenumCount := RenumStart; For Counter := 1 to HowManyLayers DO {Step through every layer, including Design Layers} BEGIN LyrTypInt := GetObjectVariableInt(LayerInQuestion,154); {***************************************************************************} {Layer type 1 is a design layer. It counts them from the bottom of the stack to the top. Ignore and go to the next layer. But count how many design layers there are. You'll need that later.} IF LyrTypInt = 1 THEN Begin NumDesignLayers := Counter; End; {***************************************************************************} {Now we're in business. Layer type 2 is a Sheet Layer Sheet Layers are counted by stacking order from top to bottom.} IF LyrTypInt = 2 THEN BEGIN IF (StackOrderBegin <= (Counter-NumDesignLayers)) AND ((Counter-NumDesignLayers) <= StackOrderEnd) THEN BEGIN NewName := CONCAT(SheetPrefix,Num2Str(0,RenumCount),SheetSuffix); SetName(LayerInQuestion,NewName); RenumCount := RenumCount + 1; END; {IF counter is in change range} END; {If LyrTypInt is 2 (i.e. Sheet Layer} {***************************************************************************} LayerInQuestion:=NextLayer(LayerInQuestion); END; {1 to number of layers} SetSavedSetting('SLRename','StackOrderBegin',Num2Str(0,StackOrderBegin)); SetSavedSetting('SLRename','StackOrderEnd',Num2Str(0,StackOrderEnd)); SetSavedSetting('SLRename','SheetPrefix',SheetPrefix); SetSavedSetting('SLRename','RenumStart',Num2Str(0,RenumStart)); SetSavedSetting('SLRename','SheetSuffix',SheetSuffix); END; {If user clicked OK} END; {main} RUN(RenumberSheetLayers); 1 Quote Link to comment
Pat Stanford Posted August 15, 2022 Share Posted August 15, 2022 The Sheet Number is actually the Layer Name. Instead of an ObjectVaribale, you can just use GetLName. 3 Quote Link to comment
sjm_htc Posted August 16, 2022 Author Share Posted August 16, 2022 Thanks both!! I didn't need to create a new node. The existing SetName node does what I need. Thanks @PatStanford for the heads up 1 Quote Link to comment
