Cloud Hidden Posted May 13, 2003 Share Posted May 13, 2003 Trying to create a page with a front and rear elevation. Since I design domes I end up having to hidden-line render with a high smoothing angle. The result looks fine, but how do I get that as one of multiple elevations on another page? Since Copy copies all the objects and not just the rendered lines, I end up Exporting a jpg, but that leaves jaggies rather than a smooth curve. So, how do I get the look from a hidden-line rendering with the smooth lines that I can copy somewhere else? Thanks... Quote Link to comment
MikeB Posted May 13, 2003 Share Posted May 13, 2003 Did you try " Convert Copy to Lines" under the Tool menu? Quote Link to comment
Kevin Posted May 13, 2003 Share Posted May 13, 2003 Cloud; If you are trying to get two elevations on one sheet, I am told, (I have not tried this), that you can use the Model tool under VW10. Quote Link to comment
Cloud Hidden Posted May 14, 2003 Author Share Posted May 14, 2003 No, that would have been too obvious... (I think I have a mental block about that one. And yes, of course it worked. This time I'll write a note for the next time I forget it. Thanks, Mike) Quote Link to comment
MikeB Posted May 14, 2003 Share Posted May 14, 2003 No problem, I seem to be the master of the obvious, and believe me it's not always a blessing. Quote Link to comment
