Using GitHub client
Hi all,
I've been using the GitHub desktop app, and I'm wondering how best to utilize this with some plugins that I'm developing. I would like to avoid copying files from the user library folder into a separate folder just for commits, but with both plugin scripts and resource files, I can't target a single folder. For some of the scripts, I could just set the environment path to the GitHub folder, but that doesn't cover my resource files, or the .vsm's and .vso's
Curious if anyone else is using the GitHub client, and what is your workflow like?
I use Pycharm to develop, which as VCS integration either using Githubg/Bitbucket/etc.
I dont use resource files at the moment (I assume you're meaning the vwr pacakges?)
Folder structure setup is as below:
- Workgroup Folder (Setup/pointed to in the Vectorworks Preferences). Eg (C:\VW Preferences\2022)
- Setting this in the Vectorworks Preferences causes vectorworks to setup the required folder structure (that vectorworks uses) for use as a Workgroup folders. Which adds folders such as: Libraries, Plug-ins, Settings, Workspaces, etc. I keep all my plugins (.vso, .vsm, etc) files in the Plug-ins folder, together with my scripts for them.
- The plugin development project folder is in the Plug-ins folder, which is what the PyCharm project points to.
- This way Pycharm manages the version control for both the script modules and the vectorworks custom plugin files (vso, vsm, vst)
By resource files, I just mean VW files in the user library that I use to import symbols, worksheets and record formats.
I had thought about using a work group, but when importing resources, for example, I need to use vs.GetFolderPath(-13) to get to my user libraries. Not only is importing from a workgroup a more arduous task, but it will break portability to any other machine, as it's all meant to be installed in the user folder.
