Add leader to callout makes VW application not responding
Christian Fekete
3 answers to this question
This is still an issue for me in VW 2024 3.1, however it is hard to recreate the issue after it happens. I rarely use the "add leader" function as it just isn't something I need to use often drafting, but frequently when I do use it, VW crashes, typically after long multi-hour sessions. VW shuts itself down after the freeze, and when I re-open, sometimes it will crash again, other times it will work successfully, repeating the exact same function on the same callout object. It happens frequently enough that I know to save before adding multiple leaders to a callout object.
