Christian Fekete
488 -
Posts posted by Christian Fekete
Why did VW change the section label setup! it used to work fine...
What a pain, there are so many things that have been changed for the worst or not working properly, viewports update work when it wants (just to think about this one) Yuk
This is what i get with the labels
The first one is on the design layer and the second one as shown in the VP. The same thing, different result. Text is surrounded by a ghost surround!
Please leave things that work alone, frustrated sorry
1 minute ago, markdd said:
It works perfectly for me.
Are you sure that you have Use at Creation set in the Edit Classes dialog.... If you don't want to use this function, then make sure you have the attribute palette set to Make all attributes by class.
I use the OIP to change that but it does not work 🤭
This is not working, please fix or advise. Thanks
thank you so much
- 1
Is there a way to drop down a layout of trees unto a sloped terrain?
Have you noted that adding a new tag line to an existing Tag will crash vectorworks? It happens on new and older files but not consistently
The Info palette of windows option "show on schedule" whether on or off does not update whether the window data appears on the schedule until the tag information is removed from the unit. This need to be resolved as even thought the windows can have data it should not show on the schedule if the radio button is turned off
I cannot remove this IFC value from the wall style, it comes back even if I check of the Set_wallcommon it reappears with the old value when I recreate a new IFC wall data
THANK YOU
There seem to be a default wall tag that I would prefer to not have (to be able to change it as needed) but I cannot change this standard value. Any idea.
File attached
Keep safe
2 minutes ago, Christian Fekete said:
It looks like your firm portfolio is quite large. Would you need help at your office or remotely? I assume that you have standards to comply with.
I would love to talk to you either in the phone or I could come down to the office. Let me know what works best for youCF
Randy,
I would be glad to help. What type of work do you do, what stage of the design process would you need help with?
we should talk, when would you be available?Looking forward to talk to you
Christian Fekete
845-625-3189
Ramona, did you call me, I don’t think I heard from you. Please try again, my phone number is 845-625-3189
I cannot show the frame of the glass door panel. What am I doing wrong? Please advise
Thank you
Ramona, please call, I work on high end residential projects and I can help to finish drawings, schedules etc. My number is 845-625-3189
Tom,
I would love to help on a part time basis. I currently work in Rhinebeck (upstate) and I go to the city once a month or more as needed. I am a registered architect with focus on high end homes. I can help with design, drafting, detailing and presentations on as need basis.
Please call directly, I would love to talk with you
My rate is 70$/hr and can be negotiated if ongoing work is available.
Best
Christian
845-625-3189
FEATURE IN WALL V.2021
in Architecture
Posted
Feature recess in walls cannot be modified, no push pull anymore!
Has this anything to do with the new feature editing new option?
please explain
Thank you
