Christian Fekete
488 -
Posts posted by Christian Fekete
Is there a way to setup a marker type (end of line) which you setup in previous file?
How do you follow a particular member whom name you know?
- 2
Hello Steven
i would love to help out. My work is mainly residential and my experience with VW started 20+ years ago. Feel free to call directly (845) 625-3189 I could start quickly.
Regardschristian Fekete
Christian@cfekete.com
@Sebastiaan Devos @Sebastiaan Devos Just spoke with tech at VW and we lowered the mesh of the imported geometry from Sketchup (symbol 3D edit, modify, simplify mesh by 75%) and we lowered the 2D conversion to low. It seems to make a difference. maybe you can try that,
good luck
@Sebastiaan Devos this is exactly what I am experiencing, another of the frustrating issues with 2021. I don't get why VW does not create a testing group before releasing their updates! I guess they have to be on a schedule. another discussion
I noticed the the backup timer is reset to 0 at time. not sure when but very annoying as 2021 crashes quite often, so frustrating
please fix it
if you can use a texture associated with a pattern ( textures with RT at the end of the name in the resource browser) and associate this texture to your roof in the texture tab of the OIP, the roof will show with a hatch in hidden line elevation and in plan
It is 3Dgeometry ghosted
if I click in the empty space i can select it and go inside the the solid substraction
it will show up when I closed the edit
Getting lots of crashes also
2021
I am not sure I understand what you are trying to achieve
I also use the suggestion fro Andy. It works really well
good luck
@Taproot do you create a text file and then a .sta file uploaded in VW or is there a prefered process ?
great post, thanks for starting this
- 1
OMG I used VW for years and Document setup but never Document settings, amazing, thanks
Thanks will try that. Does it work retroactively?
Done it before without much success
Yes this is the option to allow to show these objects. I am wandering if we can change the color from gray which I cannot see because it blends with the background.
Thank you
Is there a way to change the white lines (invisible +/-) of objects visible while in editing mode? ie group editing, so the is is possible to snap on visible objects? Is it a new version issu? could see that in previous versions
300 dpi seems to have made a difference today...thank you all
Yes I did that but it doesn’t help
Yes that’s a shame. We should be able to modify the featuring wall. Maybe next version update
Kevin, I just realized that it’s a question of scale if the Drawingsare too small the dash is showing one line
Can someone please explain to me how to show dashed hidden lines actually dashed?
Thank you
You were able to in prior release
Yes, I believe I did before
Line end marker too large on sheet layer
in Troubleshooting
Posted
my question is how do you keep an end marker type you create in previous drawing, maybe create a new standard
