Christian Fekete
    498
Everything posted by Christian Fekete
  1. I also found in previous file that grouping and ungrouping geometry will achieve the same fyi
  2. @michaelk yes I do see it in your file, thank you. How did this change?
  3. @Matt Panzer Matt, here is a simple file with a fridge provided by VW. It shows in plan but i no other views. Can you explain how to change that? Thank you SPACE PLANNING.vwx
  4. I think it is a good way to do that, it is pretty easy process
  5. How do I control the visibility of classes in a viewport directed to a design layer object which is a referenced drawing? I am not able to see the classes in that reference drawing. The alternative would be to go into the design layer and turn that class off by selecting the referenced item but I am wandering if I would loose that visibility in other viewports which refer to the same object. Maybe I could copy this reference to another layer and work from there; would that add a lot of memory to my file size? I am not sure what the best approach is, please advise . In the image below I would like to not see the plywood in the bracket detail
  6. I think this was resolved with 2020 but it is showing up in 2021. Is there a solution to these items formatting? The second line of text overlaps the symbol
  7. hmm, I probably lost those when i updated to 2021, will try again, thank you
  8. @Andy Broomell This does not seem to be working though, I do not see the new marker in following files, that would seem to be easily included in the vectorworks standards options
  9. I understand and I do that right now but it would be great not to have to look in a past drawing but to have it available in the list of markers.
  10. thank you for the new easy switch between the various spaces from the inside of a viewport, what a great enhancement !!! thank you
  11. my question is how do you keep an end marker type you create in previous drawing, maybe create a new standard
  12. Is there a way to setup a marker type (end of line) which you setup in previous file?
  13. How do you follow a particular member whom name you know?
  14. @Stéphane From Matt Panzer, kept in my assets, great video, bonne chance connecting roof in vectorworks.mp4
  15. Hello Steven i would love to help out. My work is mainly residential and my experience with VW started 20+ years ago. Feel free to call directly (845) 625-3189 I could start quickly. Regards christian Fekete Christian@cfekete.com
  16. @Sebastiaan Devos @Sebastiaan Devos Just spoke with tech at VW and we lowered the mesh of the imported geometry from Sketchup (symbol 3D edit, modify, simplify mesh by 75%) and we lowered the 2D conversion to low. It seems to make a difference. maybe you can try that, good luck
  17. so many issues still to be resolved, dispearing 3D objects (ghosted), at least crashes once a day if not more and reset of backup timer setup. Please fix these ASAP and issue a new SP Thank you
  18. @Sebastiaan Devos this is exactly what I am experiencing, another of the frustrating issues with 2021. I don't get why VW does not create a testing group before releasing their updates! I guess they have to be on a schedule. another discussion
  19. I noticed the the backup timer is reset to 0 at time. not sure when but very annoying as 2021 crashes quite often, so frustrating please fix it
  20. if you can use a texture associated with a pattern ( textures with RT at the end of the name in the resource browser) and associate this texture to your roof in the texture tab of the OIP, the roof will show with a hatch in hidden line elevation and in plan
  21. It is 3Dgeometry ghosted if I click in the empty space i can select it and go inside the the solid substraction it will show up when I closed the edit Getting lots of crashes also 2021
  22. I am not sure I understand what you are trying to achieve
  23. I also use the suggestion fro Andy. It works really well good luck
  24. @Taproot do you create a text file and then a .sta file uploaded in VW or is there a prefered process ? great post, thanks for starting this
  25. OMG I used VW for years and Document setup but never Document settings, amazing, thanks
