Christian Fekete
    488
Posts posted by Christian Fekete
  1. After many years of VW use there is still this command which is incredibly frustrating due to its bad creation process, it is incredible that after such a long availability this command is still incomprehensible. PLEASE FIX THIS ASAP. for example below the profile is connected to the corner of the bottom of the walls and top right of the profile but the resulting object is offset. the profile options do not change anything or make extrusion impossible to create. We need another command very quickly.
    thank you204258254_ScreenShot2021-04-07at16_13_27.thumb.png.aa3233f43364a7787bc03b7bc3dcdc7e.png202953879_ScreenShot2021-04-07at16_13_35.thumb.png.530a50e87fa5b2f78973dd124307786d.png
  2. @Matt Panzer Here is another simplified model for you to look at. When you open the drawing you will find selected, a ghosted piece of lumber, but this item and others will show up in wireframe mode. This ghosted lumber piece shows as a solid addition. When you open it and try to close it that there is a message indicating an impossible addition. This may be an issue but what about the other missing items,
    I have other files with entire parts of drawings showing the same (or rather not showing ). Could it be an issue with OpenGL rendering?Untitled 1.vwx
  3. If you are talking about topo, in sketchup at least when you download a google earth map view you get the rough topographical information (don't remember the height differences between curves, sorry), then you can import the topo into VW either as a 3D or just the topo curves. Works fairly well although it's a process. Good luck
    If you are talking about 3D buildings I think you can go through a similar process but if I remember correctly the buildings will come as 3D meshes which is less than ideal but that was 3yrs ago since I did that myself
  4. How do I control the visibility of classes in a viewport directed to a design layer object which is a referenced drawing? I am not able to see the classes in that reference drawing.
    The alternative would be to go into the design layer and turn that class off by selecting the referenced item but I am wandering if I would loose that visibility in other viewports which refer to the same object. Maybe I could copy this reference to another layer and work from there; would that add a lot of memory to my file size?
    I am not sure what the best approach is, please advise .
    In the image below I would like to not see the plywood in the bracket detail
    2095625975_ScreenShot2020-12-18at13_37_02.thumb.png.10bd53715af09ecb7c65574be65fa563.png
