Christian Fekete
    498
Everything posted by Christian Fekete
  1. Please take a look at this wall, the hatch (brick modular running bond HF-2) wall.vwxas defined in the renderworks associated hatch has a fill but not the rendered (hidden lines) version. How can I fix this? VWX file attached Thanks in advance
  2. @markddsoft shadows was turned off but it did not improve the edges of the shadows
  3. I can shadows on and will change that. Thank you
  4. I followed artistic style background and hidden lines foreground but the shadows edges are pixelated, How can I get these edges sharper? Thanks
  5. Is there a french language VW forum accessible from the US?
  6. Totally agree with everything said above, I love this format. It is much easier to keep track of what you missed, to move around, post and contribute. Thank you for updating, my frustration with the old forum has all but gone away. I love it. Best CF
  7. Thank you for making it closer to NYC, will make it this time.
  8. @Taprootthanks for sharing, interesting workflow. Can you explain what you mean by light that cast shadow and light that do not. Also, do you manage lights in each viewport by organizing them on separate layers, classes?
  9. Yes it seems there is a disconnect between 3D modeling (getting better) and 2D graphic standards. I sometimes think that the BIM reporting aspect of VW is worth the headaches of resolving the 2D/3D issues but then I realize that the quality of Sketchup Layout really without BIM is largely satisfying. The balance in favor of VW is the Sheet Layer which is right in the same application but then again, you have to update the viewports! Rant over, going back to voting.
  10. It should be easy to find references of this, sketchup, revit...
  11. I also would like to see that option added to the elevations where I like to have a thicker silhouette line.
  12. I think that the issue can be that the wall type exterior lines are not setup to the correct thickness. I know I updated that for my walls recently and that may be the answer. I think I remember that you control the line weight in the wall type OI
  13. I personaly think that the default user library setup is a drag and makes saving references difficult. With the issue of VW version on top, I don't really use this system of reusing resources and loose a lot of time resetting everything. Please update this and make it more straightforward, Thx
  14. total agree, the housekeeping report should not be necessary
  15. My frustration has to do with not being able to leave the orbit tool and have the object selected, same with zoom. Also, since i don't have a num pad, I can't access the various views that the numpad directs to. Also, frustrating
  16. I agree the doors AND windows need to be rethought as the complexity of the OI is such that while I make the effort to use the parameters given I cannot be satisfied that I will get what I need. Very frustrating
  17. I cant seem to avoid seeing the door tags front and back in my elevations, even the ones behind walls. what am i doing wrong?
  18. My guess is that you have to add to your symbol a text field that you link to the record field of the symbol and that should then appear on your instance on the drawing. Let me know if that works. Best CF
  19. I created a new title block but I am not sure as to what controls the fonts used in the title block, it does not seem that the fonts used in the symbol stay as attributed once I insert the title block in a drawing. For example the fonts can be changed for most of the texts once in the drawing by changing the font from the font drop down menu with the title block is selected. At that time the fonts that I attributed in the symbol are not kept but are replace by the font selected in the drawing. The only fonts that seem not to change are the ones used in the "issue" and "revision" block. Am I doing something wrong? Here is my Title block.vwx
  20. Is there a way to increase the size of the fonts used by VW in menus and OIPs? My eyes are getting less sharp and although the screens have become larger the fonts don't seem to.
  21. Wes, what happens if my spaces have already been created, I cannot add multiple space labels later on?
  22. I guess this has come back, using visibility tool by class, the toilets appear selected even where they are not (outside the building...)
