Christian Fekete
498 -
Everything posted by Christian Fekete
Construction details - Drawing and reuse
Christian Fekete replied to Christian Fekete's topic in Workflows
Thanks Eric for your insight and taking time to respond, it makes sense and seems the easiest to implement. My only question has to do with the reference workflow here. What exactly do you mean by the L-Details file, is it a separate detail file or is it part of one complete file for the project you work on. In other words do you create separate file for every sheet of your CD package? -
I am dealing with a workflow issue regarding the drawing of construction details. I am trying to solve maybe too many issues at once and I may have to make a choice on which is most important. I am trying to create a variety of details for residential construction, here are the issues: Whether to create 3D(part of the building model or separate of) versus 2D details If using 2D, do I annotate the design layer or the Viewport annotation layer How do I create a reusable set of construction details, should I include the notes in my symbols? I usually ending up doing all of the above which is very time consuming, How do you do it?
Is there a way to have VW provide the volume of an excavation created using an extrude along path ?
@zoomer I have been toiling with levels and stories for this simple bungalow that i am designing but it is not that simple. in particular where the bottom of walls and doors is located. IT IS quite challenging for me. Can you explain the best workflow to make sure the wall is sitting on a subfloor while the door opening starts on the finish floor? Thank you that will be a great help if I can figure this out. BEst CF
What's the best way to set parametric values?
Christian Fekete replied to Jimmie's topic in Workflows
what about creating a marionette script, can't you create these constraints there? -
Recommended file setup for large number of houses + site model
Christian Fekete replied to Christiaan's topic in Workflows
You could organize the house types on separate files and load them as symbols so that you can save space and update all of them at once but I would keep the site plan separate, these tend to be heavy. -
This is a long discussion, I work in 3D and try to create BIM reports from the model. Details are created and annotated on viewports from the model. Suggestion: go to the vectorworks Youtube channel there is a lot of videos on this, good luck
How about creating a wall type with a transparent or white 2.5" component to bring it to 6" but with no line, as follows, it is easier than creating a symbol, there is not return at the jambs though
vector script learning resources
Christian Fekete replied to Christian Fekete's topic in Vectorscript
thank you, it worked, moving on to the next one Best Regards -
Pat, I am going through the guide at developer.vectorworks.net and I am excited to start learning vectorscript. Q: In the following script it seems to me that I should see or hear a message but nothing happens that I can see other than the submenus becoming inactive and then reactivating. Am I not seeing something or do I need to do something in order to see something? Here is the script: PROCEDURE Example_1; CONST {capitalized to distinguish them from variables} LOCAL_GREETING_ENGLISH = 'Hello '; LOCAL_GREETING_FRENCH = 'Bonjour '; VAR s:STRING; i:INTEGER; BEGIN s:='VectorScript'; i:=2; Message(LOCAL_GREETING_ENGLISH,s); Wait(i); ClrMessage; END; Run(Example_1); -
Worksheet Formatting Scripts
Christian Fekete replied to michaelk's topic in Resource Share - Vectorscript
Thanks Michael, just saw your webcast and I was looking for these resources, can't believe I found them here, Thanks again, great help -
can someone indicate me where to go to learn vectorscript?
drawing titles jumbled up
Christian Fekete replied to Christian Fekete's question in Troubleshooting
thank you, the text style was the issue. Best CF -
Auto Hybrid object does not update
Christian Fekete replied to Christian Fekete's topic in Architecture
OK I found a solution with switching 2D/3D option in the OI back and forth it updates finally. -
When I update the 3D object constituting the AutoHybrid object, the 2D object does not update, weird. It is a bench < 4' high, no above or below special objects. Am I missing something?
this operation could not be performed because the file named "_default Hatches.vwx" could not be found This is the message I get when trying to use a hatch for concrete that I see in the resources manager. I downloaded and installed all resources from VW but I still am not able to use the hatch. What do I need to do?
Hi everyone, wish you all a happy new year and plenty of rewarding projects to all. Here is my question, I have seen these beautiful shoes in NY and I was wandering how to model such freeforms. I don't have much experience with other than architecture wall, windows etc.. but would like to move on to beign able to do that. ANy suggestion would be greatly appreciated. Best CF
Renderworks hatch has no fill color
Christian Fekete replied to Christian Fekete's topic in Rendering
my understanding was that it was possible to get a fill color in hiddenlines, I must have misunderstood Thank you
