Christian Fekete
    498
Everything posted by Christian Fekete
  1. REINSTALLED VECTORWORKS, PROBLEM RESOLVED, THANK YOU
  2. I cannot see the edges in open GL and I can't change the option, is there an option asking for that anywhere that i can change that?
  3. Previous drawings are also not showing properly anymore. I know I used a malware software to clean up my hard drive and this happened right after. Should I reinstall vectorworks to make sure?
  4. The option to setup OPENGL with shadows is greyed out, any reason for that? I have lights on the lighting plan 250217 30 High Wood Rd SD4.vwx
  5. How did it get there? I have no plans to build on the moon yet😃
  6. ahhh thank you soooo much I could not sleep over it, you’re the best
  7. this is what it looks like on my two computers.
  8. Is there a reason why my rendering in OpenGL suddenly show up as transparent. It looks like it is only in this file. If I copy just the rafters in another file it is solid with textures but if I copy and paste the whole drawings it shows as transparent. 240819 HELMREICH WD.vwx
  9. thank you, here it is -3BR-2BATHS WD.vwx
  10. I have again issues with hatch alignment. These are applied to wall components (sheathing). My setup is with the world origin but it does not line up on different layers. Arrrgh
  11. I can't get rid of the caped connections, the wall style and the joining is without caps
  12. How do I setup the dimensions so that I don't end up with fractions of inches like so
  13. this is a 2021 VW file and I run the latest Mac OS This issue is only with this file though, not other files, could this be a file setup issue?
  14. This is the only file (not new files) where this happens. I reduced the file to this one line and saved it with the name below to keep the file setup of the original file for troubleshooting and the issue continues here. New files do not seem to show this problem. Note: this is a 2021 VW file END OF LINE NOT SHOWING.vwx
  15. I have used walls and doors/windows for years and I am still baffled by how to control the classes inside these. I put my walls on walls-main and the components on their own classes. Doors have their own classes like windows but I seem unable to control what I actually can hide/show out of these. Am I the only one still struggling with these?
  16. I was able to get back my favorite in the mix and reorganize my palettes. I am not sure what I lost really. Thanks and a great weekend
  17. I changed the working location for the user data and preference folder to a new location. Can I relocate it to the previous one, I lost all the resources and favorites that I had setup before in the standard vectorworks location. Where should I look for the previous one? Please advise how to do that. Thank you
  18. Tried this indeed it is strange it is only on this file it does that
  19. For some reason on this particular file I must have hidden the drag points(below). because I can't see them. Where is this switch?
  20. @jeff prince how do you create a legend on the visualization setup of a viewport to insert on the annotation space?
  21. Hello, I cannot figure out why some joints are capped and not others. They are all defined with uncapped components, all on the same class and all uncapped walls on the drawings. Thanks for your help CF Wall join.vwx
  22. I tried this already...hmmm Thank you
  23. How do I join framing to framing instead of framing to insulation?
  24. @jeff prince OMG it works perfectly! This is amazing, I really appreciate it, thank you. I will definitely look more into this.
