C. Andrew Dunning
    1,323
Posts posted by C. Andrew Dunning
  1. I believe there might be a bug related to the text block re-sizing.  I understand how the alignments are supposed to work but the tool is adding unnecessary spaces.  See the instance in the attached file with only "-" in the 3 User-Entered Fields.  Compare with the PIO Data-associated fields in the Seating Section label D.T.
    Change Data Tag - 2.vwx
  2. I have a D.T. w. a rectangle bounding box that I want to re-size with data edits (to track a margin w. the longest of 5 fields).  So far, in trying different settings, I either get no margins or text fields that expand in  unwanted ways.  I have a similar D.T. (but, w. only 2 fields) that works as-expected with the same settings.
    Anyone give me a hint as to what I've missed...?
    Change Data Tag.vwx
  3. 8 hours ago, symo said:
    Thank you @C. Andrew Dunning
    Yes, thats right
    Food-for-thought if you want the Class structure saved in your Template:  Place an instance of the PIO in-question, change the defaults to suit your wants and get the Class structure in the Parts Classes dialog set the way you want it.  Click "OK" an let the PIO generate the Classes.  Delete the PIO instance.  Re-save your Template.  The PIO settings will be saved in a hidden Record and the Classes will be added to your Template structure.
    • Like 4
  4. 6 hours ago, symo said:
    where in VW can I pre-assign these classes before I insert any symbols into my drawing?
    Echoing Kevin...
    In the "Parts Classes..." dialog, you have 2 options:  1)  You can set each part Class individually using the pop-up menus - or - 2) You can click the "Assign Default Classes with Prefix," which will set up a default Class structure for you.
  5. 40 minutes ago, livespace josha said:
    - In the "Text Options" window, there is an option to assign a projector a unique ID. This is super helpful for big setup. ...but I can't seem to find this value in the OIP and I can't pull it into a worksheet. Any workarounds?
    2 answers:
    1. If you use the Landru Design version of the tool, you'll have "Position" and "Unit" fields visible in the OIP for each projector.
    2. While not visible in the OIP, projector ID data is stored in 2 hidden fields: "__ProjIDText" and "
      __Proj2IDText," which can each be displayed in WorkSheets.
    • Like 1
  6. 2 things:
    1. The line assigned to the "NonPlot-Loci" Class is hard-coded so you can't delete it.
    2. The reason the line is so long and the bumper isn't appearing correctly (and, that the speaker isn't drawn correctly) is that the data in the Record attached to the Symbols is not correct.  The different dimension fields all must be "Text" fields and must include the correct units marker (like "mm").  Likely, the fields in the Records attached to your symbols contain metric values but VW is treating them as imperial.
    • Like 1
  7. 2 hours ago, Sam Churzin said:
    Hello everyone! I've faced with strange a Speaker Array tool behavior. My subs and top are not at a zero point more other tops overlap each other. What is the reason of that? I've checked all my 3D geometry positioning in speaker symbols and frame symbol. Everything is at zero point. Any suggestions?
    Like @klinzey said, there is likely incorrect data in the Records attached to the speaker and/or bumper Symbols.  If you would post a file containing the Symbols you're using, I'd be happy to take a look.
    • Like 1
  8. We use a key system based on the last 6 characters of a user's VW license.  Embedded in a given key is information as to which of our products the user has licensed and which version.  This key is generated each time a user buys a license for 1 or more of our tools.  If a user attempts to use our tools w/o a valid key, the bulk of the OIP is disabled and a button to the tools area on our Web site is displayed.
    Does that help???
    • Like 3
  9. 27 minutes ago, Scott C. Parker said:
    Putting per panel weights into the LED screen tool has been suggested and is on our list of wishes for improvement.
    This feature is currently part of the Landru Design version of the tool.  Individual module/panel weights can be input, which the tool then uses to calculate, for example, an overall wall weight.  As you change panel counts, the weight updates.
    • Like 3
  10. 7 hours ago, MartinBlomberg said:
    I struggle to make an image fit on a wide LED screen. It's a square image and I want it centered on the LED-screen.
    Even though I've unchecked "Tile Image" boxes (Horizontal and Vertical) the image tiles. Since the size of the LED most likely will vary I don't want to have different files.
    First:  The way that the tool works is that, in the Edit Array Image dialog, 100% scaling means that the image fills the width of the given screen/array.  If resulting image is than taller than the screen/array, a portion of the image is then not seen/used.  You can use "Vertical Shift" to specify what portion of the image is seen/used.
    Second:  The Spotlight version of the tool only automatically tiles the given image. The Landru Design version of the tool adds a "Tile Image" toggle to the above dialog, allowing you to do things like reduce the scale so that you see the entire "taller" image on a wiser screen, center the image (using Horizontal Shift) and not tile the image, as below:
    Does that answer your question?
  11. 10 hours ago, Sam Jones said:
    OK.  What should the workflow be?
    A good question, Sam...
    My initial thought:  Something akin to the way replacing Symbols works - though, more elegant:  Select 1 or more Truss objects.  Click on a "Replace" button in the OIP.  A Resource Selector dialog opens, allowing the user to use that familiar environment to select new truss from a location he/she chooses.  The new truss is positioned using its Insertion Point. and that of the piece it is replacing.  Sections mated to the non-I.P. end would be "pushed out" or "pulled in" if lengths don't match what is being replaced.  If multiple, mated, truss sections are being replaced, replacement sections would automatically mate.  If the user is trying to mate differing truss types, he/she would be presented with an alert/error dialog.  If the resulting length is different from original, an alert/error dialog to that effect would be displayed.
    Make sense?
    • Like 3
  12. 2 hours ago, jcogdell said:
    @Ben59
    The replace truss type will only work when both truss type libraries have the same lengths available, from looking at the ST500 library it doesn't include any trusses of the same standard lengths as the sc390 library.
    Normally in this scenario you would select the truss line and use the change configuration button in the truss object properties to change the truss lengths in the line before running the change truss type command, this way the lengths in the line will match what is available in the new truss types library.
    ...and...with all due respect...this is another example of the system being WAY more involved to use than it should be...and, of why this needs a SERIOUS re-think.  The more I work with Braceworks-enabled truss, the more frustrated I get.
    • Like 4
  13. 12 hours ago, Jesse Cole Guthery said:
    Greetings. Would love if the safe lock stands for projectors had an ability to add a skirt around them. I can't for the life of me remember the last time I used one that didn't. Currently using the curtain tool to try to replicate but doesn't really have the same effect.
    The stands are Symbols that are stored in Resource folders or in your working file.  Until versions with skirts can be added, simply add that to a duplicate of one of the existing Symbols - perhaps, using something like Multiple Extrude.
  14. 7 minutes ago, John Bishop said:
    Hi,
    I have inserted the Light Instr High End Systems Solaframe 1500 into my lighting plan.
    It has something very weird showing in Top/Plan view and I can't figure out why...
    The symbol has strange "wings" which are obscuring the Lighting Pipe.
    Would you mind posting a sample VW file containing a placed instance of the fixture...with the Label Legend you're using?  The stock Symbol, itself, seems to be OK so the issue might be in your LL...perhaps, in a container shape.
  15. On 10/23/2022 at 10:15 AM, Sam Jones said:
    So this is the folder that would named "2023" and would contain the folders designated by -2, Plug-ins, and -13, Libraries, and -4, Workspaces?
    I don't know about the name...but..."yes"...to the folders it contains.
  16. Assuming you're in the Spotlight Workspace...
    [Tools][Options][Vectorsorks Preferences...]
    "User Folders" pane
    The folder cited is the one shown under "User Data and Preferences Folder."
    This folder mimics the main Application folder, containing folders like "Libraries" and "Plug-ins" for holding things like settings and PIO files.
    • Like 1
  17. 16 hours ago, aheininen said:
    Is there any way to push this to workgroup? Then all workgroup members could have inventory sizes available.
    As-formatted, the lens options, no.  But...with the Landru Design versions of the tools, things like tvs, projectors, and stands are chosen using the Resource Selector system, which IS Workgroup-aware.
    • Like 2
  18. 13 minutes ago, NBarnes said:
    I would like to edit the lists in the drop downs so that I can put things I have in my inventory towards the top.  Specifically, I would like to edit the "Stock Size" and "Lens" lists in the Object Info Pallet.  Where can I find the editable versions of those items?
    2 things:
    1. Do not change the format of any text you edit.  If you do, your tool(s) may not work and you may have to reinstall Vectorworks to get things working again.  So...proceed with caution.
    2. Any edits you make will be over-written the next time you install a Vectorworks update/service pack.
    Open the Plug-in Manager ([Tools][Plug-in Manager]).
    Click on the "Built-in Plug-ins" tab."
    Scroll down until you get to the "Video Screen" item.  Select it and click on the "Customize..." button.
    Click on the "Parameters" tab.
    Scroll down until you get to the Parameter you want to edit, select it, and click the "Edit..." button.  (Different screen aspects are stored in each of the 4 stock screen size Parameters.)
    A dialog will open.  Click on the "Choices..." button.  You will then be given a dialog showing the list you want to edit.
    When you're done "OK" out until you get back to the Plug-in Manger and click "Close."
    I hope this helps...
    • Like 1
