1,153 -
Everything posted by C. Andrew Dunning
100% my pleasure!
Dash instead of decimal point in address field
C. Andrew Dunning replied to Tory Stubby's topic in Entertainment
Change the default character for "Universe/Address" on the "Lighting Devices/Parameters" tab in the Spotlight Preferences dialog. -
At-present, no, The tool only uses the stands it creates on-the-fly.
We are happy to announce that all of our tools have been updated to make them Vectorworks 2022®-compatible! In addition to the usual on-going refinement, you might also notice minor additions and tweaks like "Vendor" and "Cost" fields, hardware Texture control for SoftGoods 2, and 3D Text Blocks for the Staging ToolSet tools. All of the tools will work in any "flavor" of Vectorworks 2018-2022. If you're a current user, you should have received upgrade details in the last few days. If you'd like more info, please visit https://www.landrudesign.com/VWPlugIns.htm Happy Vectorworking!
Curtain tool no longer working in 20, 21 or 22.
C. Andrew Dunning replied to Fergy's topic in Entertainment
Is the issue w. the Spotlight version or the Landru Design version? -
Custom Projectors with Video Screen Plugin
C. Andrew Dunning replied to ilijahmora's topic in Entertainment
...and...while the content is a few years old, this video outlining building your own custom projectors, TVs, and stands is still relevant and might be helpful: -
You can copy the Symbol into yiur current file. If the Symbol has the correct Record attached (and, the data is correct) the PIO will recognize and use it. -
Yes, that is what I meant. Sorry, the functionality you're wanting isn't part of the mix at this time...
Have you tried using the "Classes..." button at the bottom of the OIP? You can assign some or all of the parts to Classes using that dialog.
What has happened to the audio dispersion hatches?
C. Andrew Dunning replied to symo's topic in Entertainment
The hatch creation system hasn't changed in several versions. Is there any way you can post a demo file showing this problem so we can figure out whether there is something awry in the tools or in the file? -
Speaker array populate position issue
C. Andrew Dunning replied to Antoine D'Halluin's topic in Entertainment
Antoine - If you look at the "__ATS-SpkrModData" or "__ATS-SpkrModData" Record you'll likely find that the different dimension fields (Width, Depth, Thick, etc.) are using the incorrect units. First, make sure that they are TEXT fields (NOT Dimension). Second, make sure that the values they contain include appropriate units markers (mm, cm, ", etc.). If you check and fix those fields and values and then open and close the Config dialog, things should right themselves. I hope this helps. -
You likely have something in your file named "5" - could be just about anything. If you can identify and rename that item, you should be able to use "5" as a Focus Point name. In your case, it was a Working Plane. I've attached a file containing a Script that can help you fix such things down-the-road. NameFix.vwx
I believe so...
Yes. Use SetCntrlPtVis (something along the lines of "SetCntrlPtVis(ghParm,1,FALSE)").
Are you running VW 2021? Is your Workspace from a previous version? If so, use the Workspace Editor to remove the tool that is there now and add the new one that shows up in the left-hand pane.
Projector Tool(s) Comments / Questions
C. Andrew Dunning replied to trashcan's topic in Entertainment
Focus tolerances, no. Optimal viewing area/zone, yes. At-present, still only horizontal blends. Sorry... Yes, projectors for a given "blend family" can be independently-positioned. While our documentation has been updated recently, I'm not sure that you would call it a "tutorial." And, admittedly, it has been a while since I've done one of those. -
Better Projector Tool Roundup
C. Andrew Dunning replied to trashcan's question in Wishlist - Feature and Content Requests
Sorry; just seeing this thread... If the projector Symbol name includes the text "-Side" the tools know that that projector has a portrait orientation. The projector aspect parameter is then enabled, allowing you to spec. that.- 50 replies
- 3
- projection design
- spotlight numbering
(and 1 more)
Tagged with:
Replace Substring of All Symbol Names in Active Layer
C. Andrew Dunning replied to Steven Morgan's topic in Vectorscript
Have you tried the built-in Batch Rename command? -
Stagedeck Text Options in Different Views/Viewport
C. Andrew Dunning replied to TomLav's topic in Entertainment
Look at all of the potential text items that could be displayed - beyond arrows and their labels. While I, personally, might not use them in 3D, I can definitely see others' valuing that. -
For anyone following this thread... Adding a setting to echo the 2D text block in 3D within the PIO, itself, is quite doable. For decks and plugs, the text block would simply "follow" the 2D location but would be at the "deck top" height: My question: if this capability were to be included for the steps and ramp tool, would you want the text block to be at the height of the top step or ramp top? At floor level? Aligned (raked) with the angle of the steps or ramp? Something else? -
You can change the "header" height by entering different values in the "Top" "Border Width" box. Does that help?
- 2 replies
- 1
- screen
- screen size
(and 1 more)
Tagged with:
Is the speaker array tool just broken?
C. Andrew Dunning replied to djobbins's topic in Entertainment
This does sound like pretty odd behavior for the pre-Symbol version. If you'd like to DM me a sample file, I'd be happy to add it to my "take a look" list. -
Regarding bogging down...: Are you using "Symbol" mode for either bumper or speakers? If so, are your Symbols fairly detailed...what is the rendering mode for the Config dialog preview boxes...and, are the the bumper and any of the speakers tilted? If so, try less detailed Symbols or Catalog/Library mode. Highly-detailed Symbols take longer to render. in the Config dialog. And, tilting elements in Symbol mode involves creating AutoHybrid geometry for each instance in your model, which can be time-consuming. Regarding the dialog going beyond your screen limits...: Check your computer spec. against recommended minimums. With the last version, we actually worked on reducing the size of that dialog so as to work better with computers with the minimum specs. -
And...or...reach out to the developer about a possible feature tweak... 😉
