1,153 -
Everything posted by C. Andrew Dunning
OpenGL/Shaded Trouble with Curved Screens
C. Andrew Dunning replied to Tyler Forsberg's topic in Entertainment
Choose the "No Frames" Frame option. -
Editing my response... I see the issue in every rendering mode w. the Spotlight version of the tool. I then inserted an instance (w. matching settings) of the Landru Design version. Zero issues. Likely something that got tweaked along the way that has not made it into the Spotlight version, yet. -
Television / lcd / screen custom size (plugin)
C. Andrew Dunning replied to Ben3B's topic in Entertainment
You'll need to create a Symbol for the television you're wanting to show. Toward the end of the manual found here: https://www.landrudesign.com/VWPlugIns.htm are instructions as to how to do this. We also have a movie showing this here: The movie is pretty old and the tool has undergone a little evolution but the core ideas are the same. -
Replace a truss symbol in a configuration
C. Andrew Dunning replied to Mickey's topic in Entertainment
Different Symbol = different color and texture applied to 3D portion....and, embedded text label noting color w/o needing to make record changes. -
Audio Array Tool - please enable GPU processing
C. Andrew Dunning replied to Projx_CA's question in Wishlist - Feature and Content Requests
Couldn't have said it better, myself... 😉 -
Not a fancy extra script but hard-coded into the tools... -
If you don't mind poking around Vectorscript a little you might find the Worksheet and Script in the attached file to be helpful. While the dimensions get reformatted to the closest .XX", that would be easy enough to adjust. SG_Count.vwx
...and...if the Symbol name and Catalog/Library name are the same the tools will automatically grab the right "other" when you switch modes. -
You're running in Symbol mode, correct? If so, something that might help is to switch to Library/Catalog mode when initially building and placing arrays. Then, switch to Symbol mode for final drawings. That will at least help you to work quicker until you need more detailed models. Another option that may or may not be acceptable is to use less detailed Symbols. -
Non hybrid videoscreen
C. Andrew Dunning replied to fuberator's question in Wishlist - Feature and Content Requests
It is... 😉 -
I'd argue that there is a good bit (at a certain level) of similarity. For both, the Hybrid system is good for simple hangs (think horizontal truss with bottom-hung fixtures). Things break down quickly when steering away from that - which is why things like raking Design Layer ViewPorts and Schematic Views have been pursued. Designers in both disciplines need to communicate details clearly - especially, when "non-conventional" approaches are desired. Judging from threads over the years (including this one), we're still in search of a good solution... -
Sorry for the delay in replying. Lots of juggling these days... Interesting food-for-thought. To answer your first question, I'll draw a parallel w. Light Plots. There is a big difference between 2D icons shown on plots and 3D models. The latter would make for illegible plots. While, perhaps, not to the same extent, I'd offer similar thinking w. projectors, screens, and other video elements. As to your 2nd question, definitely something worth giving consideration. -
Robe Forte Needs Correcting
C. Andrew Dunning replied to C. Andrew Dunning's topic in Vision and Previsualization
Following up... It would appear that the issues I was having were because Vision does not include a Forte model, yet. So...not sure what mapping Vision was using. The remedy proved to be importing a GDTF model. Still sorting that out but much better...- 1 reply
- 1
The Mode 1 Vision DMX mapping for the Robe Forte is incorrect. I have double-checked the console library with the manufacturer spec.
- 1 reply
- 2
This definitely could be changed but might be a bit. Short-term, your best bet will be to "break" instances and add the additional railings manually.
Video screen object - classing?
C. Andrew Dunning replied to livespace josha's topic in Entertainment
Not really a bug but a simple-enough feature request/tweak. ...and...already implemented in the Landru Design versions of the tools... Thanks! -
Thanks. A huge part of the problem, here, is that making truss swaps and rearranging configurations are frequently part of the every-day "low-level" design process. Things like this should be incredibly simple and intuitive - so much so that, in a sense, users don't even think about it as they're doing it. As things stand, the current approach gets in the way of the process... -
Respectfully, I beg to differ. This whole process is light years from being intuitive. It also doesn't "understand" things like an easy swap from 4 x 10' to 5 x 8'. While, yes, a bit of adjusting after-the-fact was necessary, simple truss Symbols are profoundly more straight-forward to use day-to-day. -
With you, there. One of the more infuriating aspects of the Braceworks system... -
What is the deal with the 'Screen Aligned' mode?
C. Andrew Dunning replied to Kaare Baekgaard's topic in General Discussion
3 uses (that I use regularly) come to-mind: Creating crops of 3D views to be used in Sheet Layer ViewPorts. Creating geometry to be used for extrusions that I may not want perpendicular to the Ground Plane. Adding notes/labels/call-outs (that I want on the Screen Plane) on 3D views while working in the Design Layer space. -
Projector Tool(s) Comments / Questions
C. Andrew Dunning replied to trashcan's topic in Entertainment
Many thanks! This is the one I was trying to find because of its detailed wishlist. Have a good one! -
I was re-reading this thread from June and again saw this reference. Do you have a link to @fuberator's thread? I can't seem to find it. Thanks. -
Best way to label multiple LED wall of different sizes
C. Andrew Dunning replied to Paul S. Morrill's topic in Entertainment
The Landru Design version of that tool tracks everything you list, plus a few other things. This version will also let you display everything except manufacturer (unless you use the Note field) in text blocks embedded in the given PIO instance. See the link in my sig for more info. -
Updating Dates field in titleblock script
C. Andrew Dunning replied to Gabriel Chan's topic in General Discussion
Actually, I don't necessarily want this automated. I'd like to be able to control when this field (and, possibly, others) gets written/updated. -
What is the current syntax for using VS to write to fields in the newer (2021) format TB data format?
