1,148 -
Posts posted by C. Andrew Dunning
Here and watching, now...
Scott -
4 hours ago, Scott Hill said:Nice to know you can throw something like that together so quickly
I try to be pretty responsive to users' needs. Sometimes, I'm more successful than others. Your timing was actually quite good. Last shows of the year put to bed last week and things for 2018 haven't gathered much steam, yet.
4 hours ago, Scott Hill said:additions of geometry options would bloat things up pretty quickly, and I imagine you probably have to put the brakes on that kind of thing quite a bit.
It is really a balancing act. Sometimes, more intricacy is warranted. Other times, it gets in the way of usability. Others, it's just...to use your word..."bloat."
4 hours ago, Scott Hill said:I will say I created a (very) crude model of the MVW55 and MVW46 wall mounts, because we use them on almost every one of our videowall projects.
As wall mounts are not something the tool creates, if you tend to use them repeatedly with the same monitors you might consider creating TV models that include them. Once you know the formatting, it isn't at all difficult. A bit ago I created a movie demonstrating how to do that: https://youtu.be/ceP2MOpkGMI
Have a good one...
Scott -
The stands are intended to be a generic/general representation of the several that are available in the "real world."
Below is a 50" screen mounted on 108" poles, but placed at 48":
I was able to do both a pop-up of stock sizes and "Custom" sizes. Look for this feature in a forth-coming update of the Landru Design version of the tool.
BTW, your comment "and then alter as our clients make budget changes is a real time and aggravation saver" is PRECISELY what inspired the initial creation of the tools.
Rob -
The stand geometry is all created on-the-fly. The only "content," here, are the TV models. So, as things are currently structured, specific stand models couldn't be used if the intent is to keep things dynamic. You COULD add stand geometry to individual TV models if you wanted to (like I did for the different "confidence monitor" versions) but you'd end up with multiple versions for every TV, ballooning the library - and, IMHO, creating far more work than necessary. Just my 2¢US...
On 11/21/2017 at 4:53 PM, Scott Hill said:
It would be nice to have the stand actually be 72" or 84" as in real life, and then move the monitor up and down relative to the poles. This would show the poles sticking up like they do in real life..
Scott, a question for you (and, for anyone else interested): Would you want a simple/single ""Pole Height" parameter? Or, would you want a pop-up selection of stock heights - including a "Custom" option? If the latter, what are your stock heights?
On 11/9/2017 at 4:36 PM, Andy Broomell said:
This is similar to the Straight Truss tool's "highlight" feature for irregular pieces of truss, but that tool has a checkbox to turn it off.
Adding a "Highlight Non-Standard Slider(s)" toggle is now on The List. Thanks...
6 hours ago, Rob Books said:
because of the way that tool works, also make sure to file a bug on this if you have not done so already.
The tool is actually working as-designed. So, this would be an enhancement, not a bug - the enhancement being to separate stand/pole height and TV Z position.
Now, on The List...
21 hours ago, kevn said:
1) Can we hang a projector on a prolyte like with Wysiwyg, because I have to use the HEIGHT to stick it to the prolyte?
While it doesn't "stick," the current Landru Design version of the tool does allow you to define the trim of the truss (or, other structure) and the distance below that you want the projector to hang.
As to your video question, 2 answers:
1) VW only recognizes still images. The "Edit Screen Image..." button on the video tools' Object Info Palette will allow you to apply and automatically scale textures found in the current file or in a library folder.
2) The dialog you get when you click that button will also allow you to set up video connections for Vision.
HTH...
Check your e-mail...
On 10/29/2017 at 8:58 AM, scottmoore said:
As mentioned, I have no idea why a lighting object is required to rotate a viewport. That seems quite random to me and I would love it if someone would chime in on that.
Other disciplines use DLVPs in situations for which raking/tilting them would be problematic and this limitation is a bit of protection. For example, an architect might use DLVPs to replicate a single hotel room layout many times.
Make sense??
18 minutes ago, Wesley Burrows said:
...it would be great as an option. Not forced :-)
So, what's the emoji for having your own words thrown back at you...? ;-)
- 1
Wesley -
Your request makes perfect sense. At the same time, just shedding some light on why things are the way they are...: Different users use the tool in different ways. Some users create entire walls and see each "Module" as an individual panel. For that application, "Module Weight" could then be used to calculate a total. For other users, each instance represents a single panel (part of a wall) and "Weight," as it is now is the weight for that panel and having to know the weight for each module isn't really practical. For this latter approach, users can then generate reports that can both track data for the individual panels (tool instances) as well as calculate weights.
Make sense??
33 minutes ago, MRD Mark Ridgewell said:
Can you tell me where you find this tool? Is it in VW architect?!
Spotlight or Designer
Y'all just need to stop this. Your logic is making WAY too much sense... ;-)
+27
Yes, DLVP = "Design Layer ViewPort"
Regarding animating this, your best bet might be AnimatiomWorks: http://www.ozcad.com.au/products/animationworks.php.
Kevin -
This doesn't totally address your request but might help a little. In the attached file is a "Curved Truss Adjust" script. With a circle truss selected, it will let you change the truss width and circle diameter, retaining the circle center.
- 1
I can't get the link in your post to work, but...is the raking approach in this webinar recording the method to which you're referring: http://www.landrudesign.com/Webinar2014FollowUp.htm? Someone else might have a better/different solution but the one in the movie is the one I use on a regular basis.
Grant -
2 questions from your first request, just to make sure I'm hearing you clearly:
1) Decimal rounding: Are you meaning the "Running Length" OIP text or the on-drawing text? Or, both?
2) Leg length: Are you meaning the widths of the 2 legs that would result from a center opening being defined?
Thanks...
For anyone still following this thread, extended legs and a vertical bottom face option are now part of the official StageRamp 2 tool. Follow the link in the signature if you'd like more info...
- 1
Good catch, Josh.
Try this, instead:
Procedure ClassToggle2;
CONST
kTestClass = 'NonPlot-Loci';
kClassON = 0;
kClassOff = -1;
kClassGray = 2;VAR
DialogVisState : BOOLEAN;
VisState : INTEGER;PROCEDURE ClassSwitch(H:HANDLE);
BEGIN
IF SetVPClassVisibility(H,kTestClass,VisState) THEN BEGIN END;
END;BEGIN
DialogVisState := YNDialog(Concat('Do you want the Class "',kTestClass,'" visible?'));
IF DialogVisState THEN VisState := kClassON
ELSE
VisState := kClassOff;
ForEachObject(ClassSwitch,(ST=REGVIEWPORT));
END;RUN(ClassToggle2);
- 1
If you still want a script...:
Procedure ClassToggle;
CONST
VAR
VisStatus : INTEGER;BEGIN
VisStatus := GetCVis(kTestClass);
IF VisStatus=0 THEN HideClass(kTestClass) ELSE ShowClass(kTestClass);Layer(GetLName(ActLayer));
END;
RUN(ClassToggle);
(Just change "NonPlot-Loci" to be the Class you're wanting to control.
- 1
Andy -
At-present, the tool "thinks" it is sitting on the ground plane. Allowing for situations like you describe is on The List, though...
Andy -
The color spec'ed in the "Text Attributes" area of the "Text Optoins..." dialog controls the arrow color, along with any text you've shown.
Regards -
- 1
Video screen tool - workflow
in Entertainment
Posted
Frederick -
This isn't a bug or a problem. It is a matter of how your chosen projector models are created/formatted. So, there are 2 answers to your question:
1) You can easily create your own projector model(s). The Web page in my signature includes a link to the manual for the Landru Design versions of the tools. Toward the end of the manual there is a section giving some general information on creating custom projectors, stands, and TVs. You can also watch this YouTube movie:
It is a few years old and some of the details have changed but the general convention remains true.
2) For users holding a license to the Landru Design version of the tools, we included a couple of ultra-short-throw projectors in the latest release. While there are only 2 (for now), we included them for the very reason you cite - that they APPEAR to work quite differently than other projector models - and users might need examples of how to make things work.
