FlyingHoward
56 -
Everything posted by FlyingHoward
Yes, what Stephan said.
Hi Greg, Speaking from my own experience here as I have 2015 Designer running on a 2010 MacbookPro with Mac OS High Sierra [is quite sluggish but is not my work machine though]. As I wanted to find out for my amusement, Vectorworks 2015 will not install on my current iMac running Catalina [not for me anyhow]. HTH
Hello, I have 2021 installed and noticed there is no progress bar to be found. Perhaps I am missing something..
Installed VW asking for Activation and Serial Number
FlyingHoward replied to FlyingHoward's question in Troubleshooting
Solved by Tech Support. -
FlyingHoward posted a question in Troubleshooting
Hi all, This morning upon launching VW 2019, a pop-up asking to Activate as if my currently working version was a new install. I did a restart of my computer to no avail. Yesterday, I did use the Repair function on the VW Updater page and with no issues after that. I did send an email to tech support. Any thoughts? -
Hi MikeyP, I had a similar issue and also needed the application installer. I sent off an email to tech@vectorworks.net and got a response [and the required link] on same day. Give that a whirl.
Hi Matt, i can take a stab at it. Check the "Show Page Breaks" settings on the Page Setup dialogue?
Cannot Launch VW 2016 on 2014 iMac with OSX 10.15.6
FlyingHoward replied to Ron Prochot's topic in Hardware
Hi Ron, Others may have something to add in here, but I have read where only VW 2019 and up is officially supported on Catalina. Even though I hear of some having gotten earlier versions of VW to work on Catalina [not tried by myself]. HTH -
Unknown Dialog: receive keystrokes from any application
FlyingHoward replied to Tim Olson's question in Troubleshooting
Hi Tim, I am possibly out in Left field here but it might be due to Catalina and having to give some system permission again after an update. -
Hi Eric, please check the pdf Publish Options and uncheck "Open PDF in the Default viewer". Hope that helps you [did I understood your Q properly?]..
- 1 reply
- 1
@Wesley BurrowsFor me, the Text has full background but text is offset from the background. Fun times.
Vectorworks Preferences, Revisited
FlyingHoward replied to Neil Barman's topic in General Discussion
@Neil Barman All good suggestions for me, and especially for your reference [intended or not] to Hitchhikers Guide to the Galaxy. "Session > Maximum number of Undos > 42 Why I adjust this pref: I like to experiment and sometimes I need to “back out” of what I’m doing a lot. Plus, if it can be the answer to life, the universe, and everything, it must be a good number of undo’s." Plus I do find this setting quite useful to me. Mark -
Hello Forum users, a fresh question for someone who is willing to answer. I use VW on my External Monitor as my iMac screen, while lovely, but is too fine of a pitch for me to see well enough. While the undocked pallets load onto the External Monitor, the Main Drawing window always opens on my iMac screen. This only happens when launching VW after it has been quit, but not if opening from hidden or closed state. I do not mind moving the Main Drawing window to my External Monitor, but would love a fix if there is one. Kind regards
Increase Font Size in Palettes for VW 2019 MAC
FlyingHoward replied to Light Guy Calvin's topic in General Discussion
Great suggestions, both of you. My old eyes would appreciate such a thing. -
Hi Jim, I've a 2010 MackbookPro with HS and VW Designer 2015 that both seem to run just fine. Mind you, I do not do any serious rendering, might be a "Show Stopper". HTH
Resource Manager Moving Displays
FlyingHoward replied to Parker Battle's question in Troubleshooting
Hi Parker, Not sure if this is relatable for your setup, nor if I understand your question properly [too many Show-plans in my brain today]. I have always [when using VW2019] found that if I startup VW from my iMac dock, then your issue is mine as well with regards to Palettes repositioning on their own. However, if I start up VW by cicking an existing drawing from my documents folder, then all works as expected with all Palettes staying put. Hope this helps -
Vectorworks 2019 SP2. Beach ball indefinitely when selecting a dimension.
FlyingHoward replied to Adam Fisher's question in Troubleshooting
Hi Katherine, I think you have the same iMac I currently use. I had the same issue, although reverted back to SP 1 which seems to have alleviated some hangs. [I had reset my User Folder/prefs, along with re-install to SP 2 but ultimately had to go back to SP1]. I am about to setup a new machine with 4GB VRam as it has been suggested that 2GB VRam is insufficient in some cases. Mark -
I think I have solved my issue. I had 90 Sheets of various viewports [preset room layouts] where I would edit then publish individual sets of sheets as required. I deleted all sheets [working off of a back-up copy...], and now no more spinning beachball. I have all design layers intact still. VRAM might very well be an issue, but for now and for me, this is a reasonable fix. Thanks all.
Hi bjoerka, The no-go is that nothing had improved, same lengthly spinning beach ball after any click. Anyhow, I have reinstalled completely and have not updated to SP2. I shall see where that goes. Thank you for your help.
Hey Kevin, thank you for jumping in. I have tried the Compatibility drop down selection as well as do not use Multi-Pane Views. I have tried a new empty file, same outcome with a few lines and squares. Very strange. Maybe my iMac specs are too low. SomethIng I can most likely have upgraded..
Ugh, sad to report that it is a no-go for me on this potential fix [revert to SP 1.1]. Perhaps others will have additional things for me to try.
thank you bjoerka, will give this a "whirl".
Hi all, I have upgraded from 2015 Designer to 2019 Designer SP2 recently. Am now experiencing the spinning beachball with increasingly longer spin times as my work continues, sometimes ending with a Forced quit. Almost every click causes the spin. Watching muy Console Log while this spinning is happening, I get many many lines of the Message NSGenericException -- The window has been marked as needing another Display Window pass, but it has already had 3 Display Window passes. Restarting has no effect, nor did re-installing the application. I am, however, using Batch Converted files [event facility] with all of the same content from 2015. 2019 Designer SP 2 27"iMac Late 2015 Intel Core i5 3.2GHZ 16GB Ram 1TB HDD Radeon R9 M380 2GB VRam ASUS PB328 Monitor OSX 10.14.1 Any suggestions would be super helpful, thank you. Mark
thinking of upgrading to OS Sierra
FlyingHoward replied to digitalcarbon's topic in General Discussion
Hi jmartinarch I have VW2015 Designer, and so far have had no issues with OS Sierra. Regards -
Hi Chris, If you are referring to an iPad or other similar product, then sorry to have misunderstood your question. If not, however - I use also a Wacom Intuos Medium tablet. Works fine for me, although I do fairly simple 2D Drafting. Has been very stable with VW 2015 and 2014, speaking for myself only. Good luck Mark
