AlbertoB
    5
Reputation
0 Neutral
  1. I've just discovered that they doesn't work only in which scripts where I've used FSActlayer function to get an handle to the first object selected in the active layer. I often use this method: select an object (line, arc, text etc.) to get some information to draw another entity. FsActlayer works fine but not in "Edit Group" mode. P.S.: Other scripts work.
  2. Create a 2D Path Object. The script must contain two parts First part is used to obtain the vertex of the poly you draw with your new tool. pHd := getcustomobjectpath(me); n := getvertnum(phd); FOR i:=1 to n DO BEGIN GetPolylineVertex(phd, i, vx, vy, vertexType,arcRadius); END; Second part is used to draw your "poly break line". Inside you must define instruction for drawing break styles. BEGINPOLY; FOR i:=1 TO n DO if vertexType=0 then Addpoint(vx, vy) END; ENDPOLY; I hope to be worthwhile...
  3. When VW document is in "EditGroup" or in " Edit Viewport Annotaion" simple script commands doesn't work. Is there any part of code to add to force them start ? Thanks. AlbertoB. VW 12.5.2 Mac OSX 10.4
  4. With kOnObjPrefEventID, custom dialog now appears only when the user clicks on the preference icon button. My target is make it appear when the user double-clicks on PIO. Thank you very much for your help. AlbertoB.
  5. Reading Example 9 on http://www.vectorlab.info/index.php?title=Events#Example_9, I found out how to display the same dialog of the Preferences event.This is my script: PROCEDURE Example9; CONST kObjOnInitXProperties = 5; kResetEventID = 3; kObjXPropSpecialEdit = 3; kDefaultSpecialEdit = 0; kCustomSpecialEdit = 1; kPropertiesSpecialEdit = 2; kReshapeSpecialEdit = 3; VAR theEvent, theButton?:LONGINT; result?:BOOLEAN; BEGIN vsoGetEventInfo(theEvent, theButton); CASE theEvent OF? kObjOnInitXProperties: BEGIN result?:= SetObjPropCharVS(kObjXPropSpecialEdit, Chr(2)); END;? kResetEventID: BEGIN rect(0,0,50,50); END;? END; END;Run(Example9); How can I create a VW PIO which if double-clicked shows a Custom Dialog ? Could someone help me ? Kind regards. PS. My PIO is a point object an I use VW 12.5.
