jonHAAG
  • Content Count
    2
Community Reputation
0 Neutral
About jonHAAG
  • Rank
    Greenhorn
Personal Information
  • Occupation
    Architect
  • Location
    Zug, Switzerland
  1. David Fantastic!! This should be included by VW2008 - I find it unbelievable that they don't have a full simple list of all the shortcuts!!(Well I haven't found one.) Once again thanks...
  2. Hi there, we have exactly the same printer. We solved the problem by having an older mac running on os9 attached to our network, & using this as a "print server". We set up in OSX a dummy plotter & then always save/print our plans as "save PDF as Postscript..." in the print field. Once saved we go to our old mac & print thru the original HP print software. It sounds a bit complicated but it isn't too bad, sometimes it's even better - you can always throw the print away before you print if you realise there is a mistake. We have got all the programmes if you need the let me know. Good luck...
