50 -
Everything posted by nering
ditto, would love to find out how you fare
Elena, it sounds like the graphic on those layers got scaled at some point. If they overlay the same way than one must be smaller than the other. You can change that by making layers same scale, then going through modify>scale (inc. text, but not entire drawing) to change the wrong graphic to the right size. I've never encountered the 1/4" scale issue, but the civil drawings have come in in the past where they were drawn using 1" as 1 foot, so they had to be scaled by 12. hope it helps
Speaking of fonts, is it possible to tell VW which fonts to use? it seems to be using the ones in User Library, not System library... We own so many fonts, though some of them were purchased a decade+ ago, but VW doesn't seem to like some of them. or maybe it's the Mac+VW combo - sometimes fonts are the biggest issue with Macs and VW...
absolutely true, a lot of them are not 100% correct... prob. buggy too. might be helpful as a starting point though
you can either buy them or there is a bunch of free fonts online, like heavy hand, graphite, draftsman, etc. Not sure which particular font you are looking for
hmm, pot plants in office furniture... that made me smile:)
Only when sending to print, only the sheet plan layers (not schedules i.e.)... but, I deleted all the spaces and it works now - thanks for heads up on space tool! Also, bug submitted to VW. These spaces have not created any problems before SP3.
can't create it without renaming - same message comes up.
yep, tried. no effect. Tried custom selection, but there is nothing with that name (Room-Name) to select...
I get this message when trying to print: "The Class Definition you are trying to import has the same name as the symbol in current document" I don't have neither the class nor the symbol with that name in the file... And renaming doesn't work - I would end up renaming about 30 times per print, each time. Anyone has the same trouble?
i believe it was called file path stamp in the old days, but it doesn't show up in 2012? -bcd, cmd+click on file name only shows file path, doesn't stamp the drawing...
Anyone knows how I can show the file path/location on the drawing in VW2012? I've done it a few times in the past and remember it was super-easy, but can't find the option/tool now...
I had a file for 11-story building, 3D, BIM-friendly, with all the IFC stuff, and without the furniture, plants, people, etc. the file was 380 MB - YouSendIt came in very handy To reduce the file size I changed resolution from 300 to 150, turned off quartz imaging, simplified my GL options, and yes, final quality renderings and IFC conversions are better done during lunch or overnight...
make sure you are in the right view as well as classes/layers are set to "show/snap/modify others".
you can also hide part of it with a viewport.
If you don't want extra lines, loci, etc., but would like to just snap to each 1/5, 1/3, 1/24, etc. portion of the line, i would recommend using constraints of the smart cursor. double click the "snap to distance" button and specify which fraction or distance you want to snap to. This one's especially good if you work with a module.
I had a similar issue, but found if the tolerances are set to no fractions you can still end up with dimensions not adding up. On the other hand, if you set them to 1/4" tolerance, then the builders are still happy and the dimensions add up.
you can also just use the guardrail tool separately - more flexibility that way. Same rule applies though - if the stair design changes, then you'll end up changing the guardrail separately as well. But maybe you won't have to re-draw it completely. Would have been handy if you could get the stair and handrails to "stick" to each other though...
have you tried changing the resolution of your document? I had similar issues with some of my files. I started them at 300 resolution and they looked fine until someone else opened them and they defaulted to 72dpi...
That is exactly what I was hoping for. It'll go on the wish list I guess. Thanks for the tips Peter, sounds like it COULD be easier than I thought. I'll give it a try. CAD is definitely much faster. Fixing and modifying in just a few clicks instead of scrapping the whole drawing definitely is better. I can't even imagine doing construction documents by hand either, and the time they would take! It's just that the whole "hand-to-brain" link - it's not quite the same with the mouse... Looks like the technology is not lagging behind though... There are some pretty cool gadgets out there.
Too bad, would have been nice to create a green roof easily... I'll just do it piecemeal for now, I guess. I'm starting to miss hand drafting
What would you use for the sloped roof that is also a green/parking area? Would you create them separately, as IFC entities? I am wondering if there is some kind of landscape tool to do that in one swoop.
The file got enormous when I tried doing that and it took many hours. I attached the file I started out with and used these solids to subtract from the 22" tall floor slab.
I have to model concrete waffle slabs - anyone has any ideas? I tried adding, subtracting, but all of those take forever. Tried using the repetitive unit tool, but it doesn't look right - is there a more efficient way to do it? The ultimate goal for it is to be a solid item, that can be exported into IFC and sent to consultants. Any tips? Thank you in advance.
Jeffrey, I sent you the file, let me know if you get the same problems. I am still having issues with the floors and ceilings (converted to IFC entities) - they just won't export correctly. And, how do you draw soffits so they export well? I used short walls, with start Z at the height I needed, but they all ended up "sitting" on the floor after IFC export.
