222 -
Everything posted by Eric Gilbey, PLA
Hello @susanhutson. I was about to ask the same question as Jeff. Can you elaborate? I'm envisioning 3D interactive design, which has been possible in Vectorworks Landmark for some time. Designers typically have been used to designing in plan view, but many have been designing in 3D in recent years. With the Mutliview feature, the ability to work with both 2D and 3D views simultaneously is also possible...so as you place objects in 2D or 3D, you see the result immediately in the other view. More information about what you are seeking is needed to share a better response.
Hi Max, Great question, and I hope I can address all the questions you have presented here. Related to our recent GIS integrations and harvesting vector geometry to do so. Right now, you can bring in such geometry from shapefile formats, which usually contain open and closed polygons and points...these would usually carry data which informs the use of the lines...for instance, contour lines would contain the elevation...building footprints would likely carry the elevation of the building base, and maybe the top of building elevation, and also the building height. This all depends on the source of the GIS information. DXF files can also carry such data, and they can also be georeferenced, so may be a source if SHP files are not available. Lidar files, could be imported as point clouds and meshes, and this can also help to inform a site's terrain, but the geometry needs to be pulled out of the object and converted to elevated 3D points or 3D polygons. We can get more into that directly if that becomes the case. As for vector contour lines from image/map services in our current GeoImage process, harvesting the geometry is not yet there, but something our development team is working on. You will be able to do this, but to get the vector data, I recommend the initial steps I mentioned earlier. Regarding the other methods you mention, they are possible (DXF/DWG and tabular survey input (eastings, northings and elevations). This video describes/shows this process. Please feel free to message me if you need more information on this. Best regards, Eric
- 1 reply
- 1
@jeff prince When I started at Vectorworks 12 years ago, I tried to assemble the same thing, but as a template file. For the same @bgoff and @mike m oz stated, this was a bad idea. Now, to make a library file of all these available plants is possible, it may not be as practical as if you did this with plant objects which were preconfigured with names, sizes, 3D representations, recommended spacings, etc.. Then, I think you will have something. The challenge for the company to do this is in that we have so many users across the globe that the palette would be changing drastically from one place to another. Even in the US, we see this most distinctly in California where designers from one part of the state to the another have a vastly different plant palette because the regional microclimates require plants with different tolerances and requirements...and most importantly availability. If you are seeking a file that has every object in it without preconfigured anything (not named, not identified with an accurate 3D representation, spacing etc.) that can happen, but less meaningful to the majority of our users...this is the reason we have not assembled this yet.
Multiple viewing options for plants
Eric Gilbey, PLA replied to skeyshubber's question in Wishlist - Feature and Content Requests
VB Visual plants have built-in seasonal representations, however they are heavy memory wise so should be used judiciously. You can include an image prop for each season, but as pat says, they should be on separate classes to be able to switch out the seasons in viewport class settings. I’ve not tried this, but theoretically, this should work. -
Hello Site Design forum members. Have you been implementing any workflows which integrate with GIS data, imagery and/or geometry? If so, please reach out to us at landmark@vectorworks.net . As many of you know, we have recently joined Esri's partnership program as a Silver Tier Partner. Through this, we have several opportunities to reach other design professionals like you who are looking to improve their site analysis and planning workflows, but less aware of how GIS and related geospatial resources enable them to do that within Vectorworks. We believe that sharing your workflow examples could inspire them to do just that. The recent release of Vectorworks Landmark, Architect and Designer 2020 introduced new GIS integration features, such as Geolocate and Geoimage, which can save a great amount of time in providing georeferencing to a file, or in adding visual context for the planning work you are including as part of your project deliverables. Prior to this year's release, and still certainly available, is the ability to import georeferenced shapefile (SHP) data and georeferenced image files, such as GeoTIFF, TFW, JGW, BPW, etc.. Designers using Vectorworks could not only import those files, but they could modify them in 2D visualizations and in 3D models, allowing them to quickly add context into the projects which they are designing. So, whether you have some examples to share from the workflows we have offered before the 2020 release, or perhaps you have already been putting the 2020 new features to use, please let us know by emailing us by this Friday, October 18, and we will follow up with some communication about the potential of showing off your expertise and improved workflows. Thank you for your time in considering this opportunity. We look forward to hearing from you soon. Best regards, Eric Eric Gilbey, PLA Product Marketing Manager
- 2 replies
- 3
- gis
- site planning
(and 3 more)
Tagged with:
Hello Architect forum members. Have you been implementing any workflows which integrate with GIS data, imagery and/or geometry? If so, please reach out to us at landmark@vectorworks.net . As many of you know, we have recently joined Esri's partnership program as a Silver Tier Partner. Through this, we have several opportunities to reach other design professionals like you who are looking to improve their site analysis and planning workflows, but less aware of how GIS and related geospatial resources enable them to do that within Vectorworks. We believe that sharing your workflow examples could inspire them to do just that. The recent release of Vectorworks Landmark, Architect and Designer 2020 introduced new GIS integration features, such as Geolocate and Geoimage, which can save a great amount of time in providing georeferencing to a file, or in adding visual context for the planning work you are including as part of your project deliverables. Prior to this year's release, and still certainly available, is the ability to import georeferenced shapefile (SHP) data and georeferenced image files, such as GeoTIFF, TFW, JGW, BPW, etc.. Designers using Vectorworks could not only import those files, but they could modify them in 2D visualizations and in 3D models, allowing them to quickly add context into the projects which they are designing. So, whether you have some examples to share from the workflows we have offered before the 2020 release, or perhaps you have already been putting the 2020 new features to use, please let us know by emailing us by this Friday, October 18, and we will follow up with some communication about the potential of showing off your expertise and improved workflows. Thank you for your time in considering this opportunity. We look forward to hearing from you soon. Best regards, Eric Eric Gilbey, PLA Product Marketing Manager
How are you integrating GIS in your workflows?
Eric Gilbey, PLA posted a topic in General Discussion
Hello fellow forum members. Have you been implementing any workflows which integrate with GIS data, imagery and/or geometry? If so, please reach out to us at landmark@vectorworks.net . As many of you know, we have recently joined Esri's partnership program as a Silver Tier Partner. Through this, we have several opportunities to reach other design professionals like you who are looking to improve their site analysis and planning workflows, but less aware of how GIS and related geospatial resources enable them to do that within Vectorworks. We believe that sharing your workflow examples could inspire them to do just that. The recent release of Vectorworks Landmark, Architect and Designer 2020 introduced new GIS integration features, such as Geolocate and Geoimage, which can save a great amount of time in providing georeferencing to a file, or in adding visual context for the planning work you are including as part of your project deliverables. Prior to this year's release, and still certainly available, is the ability to import georeferenced shapefile (SHP) data and georeferenced image files, such as GeoTIFF, TFW, JGW, BPW, etc.. Designers using Vectorworks could not only import those files, but they could modify them in 2D visualizations and in 3D models, allowing them to quickly add context into the projects which they are designing. So, whether you have some examples to share from the workflows we have offered before the 2020 release, or perhaps you have already been putting the 2020 new features to use, please let us know by emailing us by this Friday, October 18, and we will follow up with some communication about the potential of showing off your expertise and improved workflows. Thank you for your time in considering this opportunity. We look forward to hearing from you soon. Best regards, Eric Eric Gilbey, PLA Product Marketing Manager -
Modifying site model to wrap around retaining walls and stairs
Eric Gilbey, PLA replied to BJRobinson's topic in Site Design
Another thought I had was two alternative options...a 3D polygon in the Site-DTM-Modifier class which traces the edges of the stair system entirely. This could act as the “retaining edge” though not having the bottom pad to make it retaining if you did want it not dig to the bottom of each stone or gabion basket, you could also trace the bottoms as one 3D polygon in the same class. The other alternatives was to place site-modifying stakes with the desired elevation entered for each position where you want the grade to meet the stair material or gabion basket face. -
Bernard, I would highly recommend the pad with retaining edge feature as an option in the site modifier list. You can find the description of how this works in the online user help page. I would recommend using the "footprint" of the separate step portions and let the retaining edge become the modifier that helps wrap the steps where you want the terrain to conform to the shape of the steps. You can reshape the handles of the retaining edge to make the grade connection to the steps exactly where you want. Each pad with retaining edge modifier can then report its own cut/fill if you want that too. -
Hans, Sure thing...the link his here. https://www.vectorworks.net/inspiration/industry-webinars/optimize-your-dwg-file-exchanges-for-site-design Also, the rest of the webinars on that page may be of interest too...so let me know what you think. Best regards, Eric
Hi Hans, Welcome to the Vectorworks community! Regarding your setup of an initial file. All of the file formats you describe (except SID) are able to be brought into Vectorworks. We just aired a presentation yesterday by a fellow landscape architect, Robert Anderson, on importing and managing DWG files. This will help with some of those questions you may have about using DWG files. Though we do not import SID files, you can bring in georeferenced image files such as GeoTIFF, JGW, BPW, TFW, etc.. If the aerail imagery you import is not georeferenced, you can bring them in and modify their scale to the appropriate size and begin working over top. Those background files (DWG and image files) should be put in a Design Layer of their own for quick turning on and off when you want to see them and dont. Many of these layer and class usage aspects are covered in the Getting Started Guides on our webpage and YouTube. We typically cover the file set-up in our online Landmark trainings (Quick Start Seminar or Landmark Virtual Training part 1. The latter has not been scheduled yet, but expected to start in January. Once these have been established, we can let you know. Best regards, Eric
Eric, Not sure if you have shared this file with Vlado and/or tech support, but it would be good to have the file to either solve the issue in the file, or file a performance bug to solve this for future large projects.
- 8 replies
- irrigation
- landmark
(and 2 more)
Tagged with:
You do not need to use duplicate along a path. The plant object has its own "along path" configuration, which you can set in the Object Information Palette (OIP) or in its plant settings when the plant grouping is selected. It seems to be set to horizontal now, but can be set to along path or randomly rotated. You want it set to along path to achieve the look you are seeking.
@lisagIf you choose the 3D polygon representation of the site model, then export the file to DWG, it will export the 3D contours as 3D polygons in DWG format.
- 2 replies
- site model
- export
- (and 4 more)
Site Model Area / Resolution Limitations
Eric Gilbey, PLA replied to lisagravy's topic in Site Design
OK...so it sounds like you are at the threshold of "either/or". Unless @techsupporthas a different suggestion. I'm not sure what else to suggest than simplification or removing every other minor interval contours, since the site model will interpolate them anyways. Perhaps the distance set in simplification could be as small as you can see a noticeable easing of articulation (ever so subtle) maybe the overlapping contours might not be as prolific and you can amend and convert to see if you have success? Using imperial, I've noticed that if 1 foot used as my distance is simplifying too drastically, I might try 3 inches (1/4 of the original simplification)...still get simplification but not as drastic. In metric terms, perhaps its by 10 or 20 cm? Don't know what the level of detail is...but in the effort you are attempting, it does not sound like you are left with too many choices in balancing the geometry/performance. Perhaps tech support may have other suggestions?- 8 replies
- site model
- landmark
(and 3 more)
Tagged with:
Hi Lisa, Though my first reaction was to simplify polygons, which you prefer not to do, I'm thinking of the Survey Input option to change 3D Polys to 3D Loci...wondering if the use of just points, and not processing the vertices and lines, would make enough of a difference in how it processes the 3D geometry. Regards, Eric- 8 replies
- site model
- landmark
(and 3 more)
Tagged with:
Offset Irrigation Pipe
Eric Gilbey, PLA replied to ericjhberg's question in Wishlist - Feature and Content Requests
@ericjhbergI apologize that the notification for Landmark conversations was broken, and I did not realize this until I noticed my notifications alert had your mention in this. After reading through the chain, here, I'd also say your original statement didn't seem so much a question as much as a statement of how you manager the multiple pipe layout in runs. Because each pipe now carries the size/flow data, it would need to be a bit more finessed, since the length of pipe (especially with a 1-2' offset here and there) could throw off the flow numbers. I'm going to share your issue with our development team and see what we can do to account for multiple pipes in a run, while graphically not losing the integrity of the irrigation layout. Eric...or anyone else, if you have specific recommendations for how this should look and act, please share them with me, directly in this discussion, to keep the topic going.- 8 replies
- irrigation
- landmark
(and 2 more)
Tagged with:
getting hardscapes to follow Site Model surface
Eric Gilbey, PLA replied to Craig D.S.'s topic in Site Design
Tamsin, hopefully Craig will correct me if I'm wrong, but from the title of his post and the descriptions he's making, I didn't think the pad modifier was it since it wouldn't have followed the surface...it would have changed the surface, and since it wouldn't slope, that usually is not preferred. -
Craig,Then the settings should not be set as a slab, but should be set as a texture bed modifier. This will not modify the terrain, but it will then map the texture to the terrain. In order for the same area to be regraded, you will have to have a site modifier in the same place "telling" it how to regrade the proposed site model. The the hardscape set to be a texture bed modifier will be shown in the rendered site model, following the proposed terrain. -
Craig, A few things may be worth checking...in the hardscape settings, does the hardscape have a class set for the main area? In the show 3D, does it reflect by class, or is another texture picked? If it is by class, does the class have the texture picked in the other "tab" (i.e. Walls, Roofs, Other). In the Site model, is it set to show the proposed site model in 3D? Do you have it set to allow only modifiers for the same layer as the site model? (if so, is the hardscape on the same layer?) the other choices would have made it more apt to show, if they were visible. -
Can't see anything after importing shapefile
Eric Gilbey, PLA replied to JessycaFrederick's topic in Site Design
Jessyca, Once you have imported the SHP files, do a fit to objects and see what it shows. Sometimes when the files come in, they are at a far different scale than you might already be in that you may need to "back-up" to see what all mat have been brought in. -
It looks as though you did not place the plants in a group, rather placed them individually. Choose the modes that follow the single plant mode and the massing should occur and the shadows will too. You do not have to check the mass plants in the definition...but the enable 2D plant rendering does need to be checked in the object information palette.
Outlander, Tamsin is right...you should watch the webinar and it should be working. Let us know what version you are using...each year, the improvements to the site model make some difference to how accurate it becomes. I have had success using 3D polygons as site modifiers so long as they are on the Site-DTM-Modifier class (also same Design Layer as the Site Model) and are surrounded by a Boundary (Fence in previous versions).
Smart point 'extension lines' snap not working
Eric Gilbey, PLA replied to Steelbreeze10's topic in Site Design
Steelbreeze, You can find hints like Cipes mentioned at the Knowledgebase, particularly the online video library. I demonstrated a tip similar to the one Cipes mentioned in our Tips and Tricks for VW Landmark 2010, with the setting a chord depth. Check out this link to see it in action http://download2cf.nemetschek.net/www_movies/2010/Tips&Tricks_Land2010.mov Knowledgebase can be found here http://kbase.vectorworks.net/ Part of the Knowledgebase is the Online Video Library found here http://kbase.vectorworks.net/categories/Videos/ I too did not have my responses in this forum tied to my emails before...but now I do...so now if someone responds or even leaves a message for me, it lets me know by email. Keep on the forum and post as you have questions...glad to have you as a part of the community. -Eric -
Well, in his question about creating a hatch, this would be perceivably a collection of linework that gets repeated within a shape. The idea of arbitrariness is forced into the shapes and orientation of the shapes so that when it is repeated, it is not too obvious that it is being tiled. Mikael, does this meet your request for creating your own hatches?
