Gilly
20 -
Reputation
0 NeutralPersonal Information
Occupation
Cartographer
Recent Profile Visitors
Script for automating tree shapes from NSEW measurements
Gilly replied to Gilly's topic in Site Design
I have a list of 150 trees in Excel with their NSEW dimensions in 4 columns. The ellispses I am drawing represent root protection areas for each tree and I am centering them on the trunk of individual trees on the tree survey. For example I would have the following dimensions: North 1m East 4 m South 2m West 7m and I have to draw an ellipse that is that shape that represents the root protection area. -
Does anyone know of a script that will automatically generate trees (as an ellipse shape) in plan view from NSEW measurements? At the moment I use a polyline and the bezier vertex mode but its slow when you're doing hundreds of trees! Can anyone help? Thanks Gilly VW 2008 Windows Vista
I am trying to import an 3D Ordnance Survey Landform Profile dxf into VW2008. It contains spotheights and contours with heights. The spotheights import fine but the contours import as extrudes and not as 3D polygons with z values which is what I need to model the terrain. Can anyone help? (The file imports fine into GIS packages). Thanks!
Cut and fill - can I find out where the areas are that have been cut?
Oh my goodness! Are you saying that I can't automatically generate a plan showing where the cut and fill areas are but I can compare existing and proposed sections across the terrain? I have to give an answer by Wednesday so any help would be appreciated. PS. Thanks for your help on this. -
I created a proposed and exising terrain model and created a rendered snapshot of the proposed and the existing terrain. I then created a viewport for them and put them on a Sheet. However they only appear as wireframe in the viewport and won't render in open GL. Does anyone know why this could be? To get around it I am having to pdf the model and import it as a pdf but it goes pixelated when I do it that way. Thanks for your help!
I am trying to add plant tags in a design layer and all the labels are too small - how do I change them? Thanks.
Can Vectorworks be used to do viewshed/Zone of Visual Influence analysis(ZVI)analysis?
I wanted a long wiggly 1.5m high hedge line to wrap over the terrain. Is that possible to do?
I have created a proposed and exising terrain model and created 2 snapshots of the proposed and existing terrain. I have created 2 viewports for them and put them on a Sheet. However they only appear as wireframe and won't render in open GL. Does anyone know why this could be?
Can font kerning be added to the next VW version as per Illustator? It would be really helpful.
Are you part of the VW development team then? Do requests from users get implemented?
I am new to Vectorworks and also use Illustrator which as you say does it easily. Are you a long time VW user?
I need to use Frutiger on my maps. It looks OK on the screen but it doen't print correctly. Any ideas? Thanks Gilly
Is there any way to change the spaces between the letters in fonts? Thanks Gilly
