Wes Gardner
Vectorworks, Inc Employee
  • Content Count
    1,276
Posts posted by Wes Gardner
  1. @Dick Jenkins...yes, I understand...that's why I chose something like the number stamp tag style as it doesn't require any object...it's sort of like a "dummy" tag.  And you can get into the tag in the Resource Manager and edit it to look like whatever you want...below is an example where I replaced the circle with a polygonal shape.  Here's the file as well...
    Tagger.vwx
    • Like 1
  2. Hi All,
    An often overlooked feature is the ability to take a hatch from the library and modify it to suit then save it as a new hatch whereupon it becomes available in the Resource Manager.
    The steps are:
    Hatch some shape with a "standard" hatch
    Select the Attribute Mapping tool from the Basic Tool palette
    Alter it as desired (corners change size, midway points provide rotation)
    Right-click and from contextual menu, choose "New Hatch from Locally Mapped Hatch"
    Voila!
    • Like 2
  3. Another idea for rendering in viewports is to set the sheet layer resolution really LOW so you get a quick initial rendering making sure all objects, the view, etc. etc. are set up correctly then jack up the DPI of the sheet to get final good-looking renderings.
  4. @Kane...your class that the walls are in needs to have a FILL...right now they have no fill that's why in openGL the walls still look like wireframe.  You may want to have a look at some of the getting started material on our website.  Additionally, you may want to have a look at the two threads that are posted at the top of the Architecture section - "No Stories, No Problem" and "Model Set-Up".  These talk you through the two types of wall styles as well as some hints on setting up a file.  There are sample files there as well.  I would start with "No Stories, No Problem" to get a firm understanding of a layer-bound wall style, how it's created, how it can interact with slabs, etc.  "Model Set-Up" talks about using stories to help define the height of certain elements that are "story aware."
    Wes
  5. In fact, we recommend doing your rendering in viewports...and as fabrica points out, you can change the DPI of the sheet layer...I usually go to 300 for anything rendered.  Yes, it takes a little longer for the rendering...
    • Like 1
