Wes Gardner
Vectorworks, Inc Employee
  • Content Count
    1,386
Everything posted by Wes Gardner
  1. From the OIP, WITHOUT having to go into the Settings dialog, be able to place a Window's (or Door's) ID in a Class (like Window-Spec) If this were possible, one could use Custom Modification, select Window and using the Plug-In "Re-sequence Openings" number all their windows sequentially and place the ID tag on the Window-Spec class. This can't currently be done can it?
  2. In the Create Section Viewport dialog box, when you create your section find "Advanced Section Properties" where you'll be able to limit your section's length
  3. Hey Ronman, Can you "capture" this anomaly and submit a bug?
  4. I'm not certain you CAN edit pattern fills, hatches on the other had are editable in the Hatch Editor. Unfortunately my expertise (what little I have) jumps from version 10 to 2008 - I do recall editing hatches in v10 was a tedious process.
  5. Here's the poop on Fonts as I understand it - if you want the font to stay as you set it in your custom block, DO NOT check Pen Style in the Attributes Panel. I haven't tried it with line weights but I suspect it's the same scenario...
  6. I think the Class is Ceiling-Main and yes, the purpose is for RCPs, when that class is ON, lines will be drawn at your window and door openings indicating the wall above - you can adjust the line weight for these in the Door/Window Settings panes in VIEW >> PART >> Wall Lines
  7. In your Roof Class, if you go to Edit Class(es), there's a "ROOF" button about half-way down allowing Texture - "Top Texture" and "Dormer Texture", they can be different...this is for the SIDES of the dormer
  8. Once the Title Block is placed on the sheet, go to the Object Info Palette and find "Title Block Position" where you can select "Top Left"
  9. And yes, go ahead and set the jamb thickness to "0" and you'll get an arch...furthermore, if you mess around with the springline setting when a segmented shape is selected, you can get different arched shapes.
  10. Oops, guess I wasn't making myself clear - what I meant is if let's say, you have a section on a Sheet Layer, if it's out-of date you'll see a red candy cane stripe around it - by double clicking, you can enter the Viewport at its scale and embellish it (as opposed to drawing over the top of said section on the Sheet Layer). Obviously, you can do this even if the Viewport is up-to-date, there just won't be the candy-cane bounding box around it... Sorry for the confusion
  11. On a Mac it's Apple K...so maybe on a PC it's Control K...? Didn't there used to be a command "Symbol to Group" or something similar
  12. Rather than drawing on the Sheet Layer and having to do the math to convert to scale, you may want to try double clicking on the red candy cane stripe of the Viewport on the Sheet Layer which brings up a dialog where you can edit Annotations - this allows you to draw at the scale of the Viewport. From what I can tell, the only "drawing" I do on the Sheet Layer is to place the Border and title Block. Everything else is "imported" via a viewports and placed on the Sheet Layer - sorta that "presentation board" concept. The concept of scaling a Design Layer may be a "Legacy" thing as there were no viewports years ago. Seems now you could draw at 1:1 on Design Layers and then "throw a scale on it" when bringing the Viewport onto a Sheet Layer. What you could have done with your text experiment is on the Design Layer create a Viewport and place it on the Sheet Layer at a scale of 1:48 - I think then you would have gotten the results you expected. From an AutoCAD perspective - Design Layers = Model Space and Sheet Layers = Paper Space...I'm no AutoCAD guy so I really can't expound too much more with that...
  13. Also, in Design Layers you can't have Stack Layers on if you want to Show/Snap/Modify Others...
  14. Hey Brooke, To be honest, my knowledgebase has a big gap in it - I jumped from v10 to 2008 consequently I'm not entirely sure how/what the workflow is for 12.52. Certainly islandmon's methodology is sound. In '08 once I've created a Sheet Layer, I can go to page set-up and pick a size, say ArchD (24"x36") and then go to my Dims/Notes tool set, grap a border (that auto-sizes for the selected page set-up) pop it on the sheet, then in the OIP, select a Title Block and voila! There are some other automated features in Document Setup. Sorry for any confussion
  15. You're on the right path - Sheet Layers is where Title Blocks and Borders should go. Their scale is 1:1. Think of them as a presentation board - you can have different views at different scales and different rendering modes on your "board." As you've seen, the Viewport can be scaled to fit your design ideas on the sheet. You can then use Class Overrides within a viewport to manipulate the line weight, color, etc. I typically place my base dimensions (most of the exterior dims) on the Design Layer - I can then toggle them on and off for views that don't require dimensions (like presentation plans) or an electrical plan maybe.
  16. You can "grab" a script from one file and import it to another by going to the Resource Browser, finding the VectorScript Palette (folder) double click to open and that's where your scripts are stored for that file, in your new file use the Import function to tranfer your script to the new file
  17. I tried moving a plan viewport and it had no effect - rock solid stable and same results with a section viewport - even if I move the section viewport, the plan stays in-tact, same the other way 'round I'm on a Mac? In theory, platform shouldn't have a thing to do with it...but that's THEORY?? Sorry, I can't make mine mess up...
  18. Can you be a little more specific, when you say "move" is that just relocate on same sheet or create another sheet and move it there (or another scenario?) and move which, a section viewport or a plan viewport? And yes, I'd be glad to help.
  19. You CAN locate your section lines in the plan viewports of your final drawings. Here's how - Go to one of your section sheets, single click the viewport there, go to Section Line Instances in the OIP, toggle the button to show you the list of VIEWPORTS, select the plan viewport you wish to have your section "bug" occur on and Voila! You may have to "mess around" (technical term) to get your class visibilities where you want them but that's how it's supposed to work If you send me your e-mail, I'll attach a file (residential scale) showing this process Wes
  20. My understanding is that things 3D cannot be shown as dashed. What I do for beams, etc. overhead is make a hybrid symbol with the extrude being the 3D component and let's say a rectangle (dashed line) making up the 2D element - combine into Symbol and voila!
  21. I can't get it to happen for me...I wonder if it's some sort of platform-specific thing? I'm on a Mac.
  22. With things architectural the Space Tool gathers information as you've seen within the "Set Additional Data." This is the location for entering room finishes for floors, walls and ceilings - the data can then flow to Room Finish Schedules, Door & Window Schedules, etc. depending on how they are set up and what data you are interested in displaying.
  23. What I have done with, for instance, the Window-Spec class is make it a unique color, then when I assign my Window ID numbers, it becomes a visual clue that they are in the correct class so I don't have surprises down the road when I go to make presentation plans (where I typically don't show the window ID info) vs. CD-type drawings were I DO want that info to show...
  24. Michael, Have you got your section info worked out...once a section has been cut and placed on a sheet, you need to go to the Object Info Palette (OIP) and as CS1 suggests, down near the bottom is a "button" called Section Line Instances - this is where you can tell VectorWorks on which drawings (Sheets) to place your section markers... Is this what you're looking for?
