Wes Gardner
Vectorworks, Inc Employee
  • Content Count
    1,313
Everything posted by Wes Gardner
  1. I am not a Cinema guy, but one of the folks here on the mother ship is and he just loves it...Cinema's forte of course is animation, something that we just touch on....additionally, Cinema has many more effects/shaders/etc than we offer in our Renderworks package. What's cool about the interaction between Vectorworks and Cinema is the ability to up date your Cinema model once the initial transfer occurs, also the organization scheme in Vectorworks (Classes) is maintained in Cinema making it pretty easy to find and manipulate the geometry, add/alter textures, cameras, etc. Wes
  2. Notice that a typical door (one without sidelights) draws just fine without any additional input. It's when you include lites that it wants to automatically center itself whereupon you have to start "forcing" it to the outside...
  3. Currently, we don't draw the stop bead in either 2 or 3D. This keeps the complexity of the element as simple as possible and also helps to reduce file size. I suppose if it were requested, we could include a profile that includes the stop....
  4. Here's something that'll get you close... "Use Jamb Extension" - this is based on an 8" wall (but it could be anything) Offset in Wall - 3 1/2" Do NOT use "Use Wall Depth" Jamb Depth - 3" "Use Jamb Extension"
  5. And then if I move the sculpted object out, I get this...seems there's something going on with the multiple profile objects and EAP...
  6. How 'bout this...if you zoom way in, the profiled section is separated from the main square shape whereas the shapes, etc. on the left are all touching and therefore are homogenous...is that the right word???
  7. On the "unhatched" profile, if I "Add Surface" the two profile objects - the rectangle and the sculpted shape, all is well...
  8. Here's what I'm seeing - the handrail offsets in 2D...see the two attachments - under the RAILINGS tab "Show" handrail, then type in an offset "Offset to Tread Edge" - sorry about the crazy feet/inches thing... Then under the 2D GRAPHICS tab choose "Show Handrail." Is this what's needed?
  9. Hi Christiaan, I just tried a straight run of stairs "out of the box" and mine seems to be working as expected. Has yours been localized with perhaps an "oops" Sorry, my graphic is just 2D so you really can't tell which way is "up", but when I go to 3D, it's correct... Wes
  10. Hi Bradley, You can use my name and email address - wgardner@vectorworks.net. I'll do my best to get this resolved - thank you for pointing it out. Wes
  11. Additionally, some of the hatches that ship with Vectorworks are Page Based which I tend to convert over to world.
  12. Hey Neil, I sent an email - just be sure that the 2D shapes you start with are CLOSED polygons and that they have a fill (any color will do). Then extrude into 3D space with the Extrude command. Sometimes it's easiest to just create a big solid chunk that becomes the object that you use to do the subtracting from the geometry you want to keep. Maybe start with some simple shapes first until you get the "hang" of it...
  13. Hi Ross, In fact, this is a very good question. Keep in mind, in some render styles, that "dividing line" WILL show. It should NOT show in Hidden Line rendering as well as Custom and Final Quality Renderworks. This of course assumes you have good alignment vertically (in other words, walls stacked EXACTLY on top of one another). Also, depending on the exact construction technique at the floor/wall intersection, you may have to place an offset on the component of the outer wythe of brick in the Wall Style - this offset forces that component to "run long" covering up the side of the floor system. Another method that can be used in relatively simple conditions is to tell the floor system's (slab) components how to respond to an exterior wall. In this case, the walls are stacked directly on top of one another and the slab "knows" to interupt the inner component(s) but stop just behind the outer component (your outer wythe of brick) resulting in no "line". Keep in mind, if you have a complex assemble, in many cases, the slab won't be able to be "auto-bounded" and you'll need to revert to using offsets in the various components of your Wall Styles. I've attached a Story Set-Up worksheet - it uses cheesy American wood construction, but hopefully shows how components can be dealt with. For example, in the floor system that's shown, the structural system and the sub-floor stop just behind the wall sheathing whereas the finish material stops just behind the inner component (the drywall). It'll take you a bit to get your head around this, but once there, it's a pretty cool system
  14. Here's a 2013 version, and yes, 2014 is shipping as of September.
  15. Actually it's even more rudimentary than that...I set my model in a side view and drew a couple of lines representing the two roof pitches. I then used the fillet tool to create the rounded transition. I then used the offset tool to create a closed polygon and then extruded it. I then set my model in top/plan view and duplicated the new "roof form" at the ridge also duplicating the extrude 45 degrees to create the hip. I then subtracted some solids to get rid of the unwanted pieces and that's pretty much it. Not alot of "automation" but it gets the job done. File included
  16. There are a couple of ways - the simplest is the method you've pointed out - use two roof objects for the two roof planes, however, you will get a "hard" break. To soften the break, you'll need to model the entire roof object - Wes
  17. Hi Neil, In many cases, I use the automated dormer feature as a preliminary design tool. Once the general appearance is established I'll break the thing into individual walls/roofs/ etc. to complete the documentation of the project Wes
  18. To edit the dormer placement, click on the blue node associated with the dormer object, you'll then be presented with a dialog letting you position the dormer.
  19. Bravo Christiaan, thank you for posting this...!
  20. Hi All, Here's what I understand...the Wall Framer creates extrudes whereas both the Floor Framer and Roof Framer create Framing Member objects. I believe we'll need to see a shift to getting the wall framer to create those same Framing Member objects. This will let us define the profile of the member (wood, steel stud, whatever). This has been Wish Listed. Thanks everyone for pointing this out. Wes
  21. Oops, sorry Steve, I overlooked that - I thought you were objecting to your original image where in plan view, the window seems to be sticking out well beyond the brick face...I'll go back and have a carefuller (more careful ;-)) look at it - I have an "in" with the "window guy." Wes
  22. Is it possible to post a file where this is occurring so we can have a look?
  23. Hi Steve and Christiaan, Here's mine...it appears in my iteration that everything is OK. This is on a Mac, dunno if that's the issue or not but I'll alert our friendly folks in tech support and see if they have a solution. Wes
  24. Were you able to switch out the prefs folder? That will probably be Tech Supports first answer...
  25. In case you decide not to upgrade, another method is to limit the depth of the elevation so that the far side of the building isn't "seen" in the "cut"
